How to Refinish Cedar Paneling
what you'll need
- Sandpaper
- Scraper
- Bleach and household detergent
- Sponge
- Paint or varnish
- Paintbrush
- Water and hose
Cedar paneling is widely preferred by home owners due to the durability, beauty and appealing scent of this coniferous wood. Cedar paneling can also be refinished to produce a more beautiful and earthly appearance. You only need a few simple tools and materials to successfully undertake this fun and worthwhile activity.
Step 1 – Scrape Old Finish
Use a scraper to remove loose bits and pieces of the old finish from the cedar paneling. You may opt to leave the hard-to-remove parts of the finish on the wood.
Step 2 – Sand the Surface Smooth
Use sandpaper to sand the surfaces smooth. This will enable you to expose the old wood finish and further remove traces of the old finish on the cedar panels. Judiciously sand the surface to achieve a smooth and fine appearance.
Step 3 – Wash the Panels
Mix a capful of bleach and a small amount of household detergent to 2 liters of water. Dip the sponge in the soapy mixture and wash the cedar panels to get rid of fungus and other bacteria that may be present on the wood. Rinse the panels with a hose and wipe dry. Let the panels dry completely.
Step 4 – Apply Finish
Use a paintbrush to apply your finish of choice and let dry.
Remember that you can safely restore cedar paneling and other wood finishes provided that there are no visible signs of rot or decay on the surface.
