Login Error
Close
How to Refinish Plywood Cabinets
by DoItYourself Staff
what you'll need
  • 100-grit and 280-grit sanding sponge
  • Duster
  • Soft cloth
  • Wood stain
  • Stirring stick
  • 2 natural-bristle brushes
  • 2 painters rags
  • Sanding sealer
  • Wood varnish
  • Foam brush
In the world of furniture making, plywood cabinets are a popular item made from thin layers of natural wood. The panels from plywood are used in the furniture industry, particularly wooden furniture. Its popularity rose because of the versatility of design, texture and size. But over time, the texture of the plywood, particularly plywood cabinets, lose their smooth finish. Appearance of dullness on the wood may be seen as color and smoothness fades. The best way to treat the dullness on plywood cabinets is to refinish the wood by applying stain and varnish. This procedure will condition again the plywood’s color and texture and give it ample protection.
Step 1-Applying Sanding Sponge
The plywood cabinet must be polished using a 100-grit sanding sponge. With the sanding, take out all traces of the existing finish. This is the preparatory step to applying wood stain on the plywood.
Step 2-Clean Up After Sanding
Sanding the plywood cabinet will leave sawdust and other residues on it. With a duster, wipe the cabinet surface to clean it up. Wipe the area again using a soft cloth to get out the remaining dirt and make sure that a clean foundation is created.
Step 3-Applying Wood Stain or Paint
Using a stirring stick, mix a can of wood stain or paint. Making even brush strokes, paint wood stain onto the plywood to be able to restore the color of the plywood. Use a natural-bristle brush when applying the paint, making sure that the direction of the grain is followed. Any excesses to the wood paint application must be wiped off.
Step 4-Sanding the Surface after Drying
Allow the wood stain or paint on the plywood to dry completely following the indications on the product label. Once the paint has already dried up, apply a sanding sealer on the surface. A natural-bristle brush is recommended for use. Again follow the direction of the grain of the plywood. The sealer must be allowed to air dry. Using a 280-grit sanding sponge, smoothen the surface to generate an even texture.
Step 5-Protection Application on the Plywood
To give protection to the plywood, polyurethane wood varnish must be brushed onto the plywood. This will seal and protect the wood’s restored condition. When applying the wood varnish, use a soft painter’s cloth or a foam applicator brush. Let it stand overnight. After this procedure, smoothen the cabinet using a 280-grit sanding sponge.
Step 6-Application More Coats for Protection
The wood varnish must be applied again on the plywood for another application or two. Repeated procedure on the coating is necessary because it will prevent the moisture from the plywood over-drying and cracking. The top coat must not be sanded.
 forum activity
