Login Error
Close
How to Remove a Concrete Slab
by DoItYourself Staff
what you'll need
  • Large sledgehammer
  • Chisel
  • Small hand sledgehammer or heavy hammer
  • Circular saw, or a wet circular saw to reduce dust
  • Circular saw with a diamond masonry blade
  • Hammer drill with masonry bit
  • Jackhammer (optional but recommended)
  • Safety glasses
  • Gloves
  • Dust mask
  • Steel-toeboots
  • Ear protection
  • Crowbar
  • Wheelbarrow
  • Pitcher of water and glass
  • Hacksaw
  • Truck for disposal of concrete
Sometimes, when creating an addition to your home or remodeling, you will need to break up a concrete slab from a patio or other area. Removing a concrete is a labor-intensive job, but it is not too difficult. To help make the task a little easier, here is a simple step by step guide that will show exactly what you need to do in order to rip out that old slab quickly and efficiently. Let's get started.
Step 1 - Prepare to Work
Before you begin the demolition and removal of the concrete slab, put on all of your safety equipment. Breaking up is a dirty, dusty job and potentially dangerous job if you are not careful and prepared. Safety glasses, gloves and steel-toe boots are a must. Since you will be working with loud power tools, ear protection is strongly suggested as well. Although the money you save by doing the work yourself will be quickly be lost if you injure yourself and have to pay for a trip to the emergency room. So, be prepared before you work.
Step 2 - Cut Concrete Slab in Sections
Install the diamond masonry blade onto your circular saw. Then, take the circular saw and start to create cut sections in the concrete slabs. Keep the sections fairly small so that they will be easier to break up with the sledgehammer or jackhammer. Use the saw to create rectangular or square section in the slab. When you finish, the concrete slab should look like an extended tic-tac-toe game drawing.
Step 3 - Break Up Concrete Sections
Use the large sledgehammer or jackhammer to begin breaking the cut sections. This is the back breaking part of the job; so, take frequent water breaks so that you don't become dehydrated while breaking up the concrete. Continue breaking up the concrete slab until the pieces are small enough so that you can carry them to your wheelbarrow.
Step 4 - Break and Pry Out Pieces Around Rebar
If your concrete slab has rebar installed, you will need to use the small sledgehammer or hammer and chisel to break up concrete in areas where the big hammer or jackhammer cannot reach. In tight spaces around the rebar, you can use the pry bar or crowbar to pry out the pieces. Once you clear the concrete around a piece of rebar, use the hacksaw to cut it into smaller pieces (that will fit in your truck bed) and set the steel piece aside. You will dispose of it later.
Step 5 - Load Up Concrete and Haul it Away
Load up your truck with all of the broken concrete pieces and steel rebar. Then, take it to the landfill and dispose of it the area assigned for this type of material.
 forum activity
