How to Remove a Deep Car Scratch with Household Items
what you'll need
- Shoe polish
- Cold water
- 2000-3000 grit sandpaper
- Liquid dish detergent
- Bowl
- Soft brush
- Soft cloths
- Terry cloth towel
- Rubbing compound
- Car wax
- Polishing wheel
Many of us have had to remove car scratch marks at some point. You may go to great lengths to avoid scratches but sooner or later, your car will bear the unavoidable marks. Scratches spoil the appearance of your car. They also reduce the resale value of your vehicle if not properly removed. Scratches are not the sort of thing you can afford to ignore for too long. It is best to deal with them as early as possible. Fortunately, you need not take your car to a body shop for scratch removal. Use the following household items readily available in most homes to do the job. It’ll save you some bucks and improve the appearance of your car with just a bit of effort.
Step 1 – Wash the Panel
Wash the panel with soapy water. Rinse and dry with a soft cloth. It is best to repair the scratch after the panel has been well cleaned. This will ensure a better outcome.
Step 2 – Apply Shoe Polish
Use a soft cloth to apply some polish over the scratch. This will allow you to sand down the paint around the scratch and not exceed the scratch level. If you exceed the scratch level, you’ll cause more damage to the panel.
Step 3 – Sand the Scratch
Add 2 drops of liquid dish detergent into a bowl of cold water. Mix the solution well. Dip 2000-3000 grit sandpaper into the bowl, then sand the affected area. The slippery solution will enhance the action of the sandpaper. Use short light strokes to sand until all the polish disappears. You’ll have to re-dip the sandpaper in the soapy water as you work to ensure efficiency. Be sure to work over the entire length of the scratch.
Step 4 – Clean
Brush all sand particles from the affected area with a soft brush. A clean surface is vital before you proceed to the next stage.
Step 5 – Buff
Use a washcloth to apply some rubbing compound on the scratched area. Work in a circular motion. As you buff, a haze will be produced. Use a terry cloth towel to lift the haze.
Step 6 – Wash
Clean the mended area with plain water and a soft cloth.
Step 7 – Polish
Work the area with a polishing wheel and compound. Once you notice that the area has a uniform appearance with the rest of the panel you can cease to polish. Wipe the area with a soft cloth to prepare the surface for wax.
Step 8 – Shine
Use a soft cloth to apply car wax over the area. Rub the wax in a circular motion to create a shine. Car wax also acts as a protective layer for your car. It helps to prevent further scratches. This final step will leave your car in good shape.
Tip
- Be careful when you buff. If you overdo it, you’re likely to damage the paint on the panel.
