How to Remove a Toilet Fill Valve
what you'll need
- Pliers
- New fill valve
- Sponge
A toilet fill valve is designed to maintain the proper water level in your toilet tank. A faulty valve could cause the toilet to overflow. You can simply and easily repair a faulty toilet fill valve by yourself.
Step 1 – Preparing for the Valve Repair
Turn the valve under your toilet tank in a counter clockwise direction. This will turn off the water supply to your toilet. Remove the tank lid and place it in a safe place to protect it from any accidental damage. Flush your toilet to remove the water from the tank. Use a sponge or towel to soak up an moisture left in the toilet bowl.
Step 2 – Removing the Valve
Use your pliers to loosen the nut under the tank. Remove the nut, washer and lock nut. Raise the pipeline fro the overflow tube. Remove the fill valve. The valve is connected to a rubber ball float.
Step 3 – Replacing the Valve
Position the new valve in place of the faulty one. Tightly secure the lock nut, washer and nut. Position the pipeline into the overflow tube.
Step 4 – Finishing the Repair
Turn the valve under your tank in a clockwise direction in order to reconnect the water supply. Carefully position the lid on top of the tank.
