Login Error
Close
How to Remove Adhesive from Drywall: Dos and Don'ts
by DoItYourself Staff
what you'll need
  • Large cloth or old newspapers
  • Soft dry dusting cloth
  • Soft mop
  • Warm water
  • General adhesive removing materials like Goof Off
  • Detergent (dishwasher sprays, liquid soaps etc)
  • Hair dryer
Whenever we are going to repaint or retile the old wall we face a big problem as to how to remove adhesive from drywall. Adhesives on the wall come in many forms as wallpaper adhesive remains, duct tape adhesives, adhesives mixed with paint, adhesive layers due to many layers of wallpapers etc. And when you want to repaint the wall, they pose a big problem. Glue remains take away the smoothness of the wall and destroy overall look of the room.
Step 1 - Preparations to Remove the Adhesive
Before you start to take off the adhesive from the wall, you need to cover the area surrounding the wall with loose cloth or old newspaper so as to collect all the fallings from wall. Wear your safety glasses and gloves. Also check if there are any electrical openings around, if yes, then cover them properly.
Step 2 - Identify Adhesive
Before learning how to remove adhesive from drywalls, you need to identify the type and cause of the adhesive on your wall. Some adhesives, like the wallpaper leftovers, can be easily removed by hot water and soft scrub.
Step 3 - Removal Procedure Using Scrubbers:
The most easy way to remove the adhesive is to scrub off. The liquid solvents can be used as scrubs. The adhesive removers are solvent scrubs and are generally enough to take care of left adhesives. Mix some dishwashing powder with warm water and spray it on the walls. Using a damp cloth, wipe the wall with some pressure and your walls will be good for any of your experiments.
Step 4 - Removing Tape
Wear gloves for this step. The duct tape on the walls has very strong glue bases that can peel off your wall paint along with it. Gently raise a corner of the tape and, using a knife or blade, start cutting the contacts between the tape and wall, to help it come off easily. Wipe off the adhesive on wall with warm water. The tape can be removed by heating it with a hair dryer and then peeling it off.
Step 5 - Professional Help
There are companies which make exclusive adhesive remover products like The Wagner. They make wallpaper steamers that melt the glue on the wall which you can simply wipe off. The process involves a lot of heat and is messy, but surely works. But you need to be cautious and careful. Also, you can give the whole job to some professional cleaning company.
     forum activity
