Login Error
Close
How to Remove Aluminum Storm Windows
by DoItYourself Staff
what you'll need
  • Ladder or stepladder
  • Drill with screwdriver drill bit
  • Rubber or latex gloves
  • Utility knife
  • Removable tape
  • Paper towels
  • Window cleaning fluid (you can substitute 2 cups of white vinegar mixed with hot water for the cleaning fluid for greener cleaning)
  • Bubble wrap or old blankets (for wrapping and storing windows to prevent breakage)
Exterior aluminum storm windows protect against drafts and create a secondary glass barrier between the exterior and interior of your home. They also increase the energy efficiency of your home. By adding this additional protection you can save on your heating expenses and see a return on your investment of buying aluminum storm windows. You will see an energy savings of more than 720,000 British Thermal Units (BTUs) annually.
Your exterior aluminum storm windows will need to be removed in the spring due to warmer weather. Ample storage space may be needed to house the removed storm windows depending on how many windows you have. The method of removing your storm windows can be accomplished by following the steps below. It is recommended that you work with a partner who can help you with any of the steps if needed.
Step 1 - Set Up Your Ladder or Stepladder
(If you have a single level home, skip this step.) It is recommended to start your aluminum storm window removal at the top floor windows of your home.
Make sure that your ladder or stepladder is locked into place and sits firmly on a level surface. Be careful with your footing as you climb and do not stand at the very top to work safely.
Step 2 – Storm Window Removal
Using your drill with a screwdriver bit, unscrew the storm window from the existing window frame. Save the screws for re-installation in the fall by wrapping tape around the screws and then taping them to the storm window frame.
If you have removed the screws and the storm window is stuck to the existing window frame, run your utility knife around the seam between the windows to loosen the window and gently pull the storm window from the frame.
Use care in storm window removal. Do not try to force your storm window from the frame as it can result in window breakage. You can also be injured by the broken glass.
Step 3 – Clean the Storm Windows
Before storing your aluminum storm windows, make sure to clean all of the surfaces. Use either a glass cleaner or vinegar solution and wipe clean with paper towel. Allow the windows to dry completely before storing.
Step 4 – Wrap and Store Storm Windows
Wrap the removed storm windows in bubble wrap or old blankets after cleaning. They will need to be stored in a safe and dry place where they will be protected from weathering and breakage.
 forum activity
