How to Remove Bite Marks on a Nursery Crib
what you'll need
- Screwdriver
- Plastic Rail Guard
- Iron
- Wet Cloth
- Sand Paper
- Matching Stain
- Clean Cloth
A nursery crib can turn out to be a family heirloom, as it is passed down through the generations. There is a lot of history, memories, and sentimentality when it comes to the nursery crib, especially if it is from the first born or only child. The nursery crib can go through many different homes and rooms in its life. Because of this, there may be some damage to the crib that needs to be repaired. Once such damage that should be repaired before handing it down is bite marks in the railing. Removing these bite marks is an easy process with the right steps.
Step 1: Sand Railing to Remove Gloss
Wooden cribs usually have some sort of stain on to protect it. After the baby bites through the wood, there are going to be small impressions throughout the top of the railing. The first step to remove these bite marks is to carefully sand the wood, to smooth over the marks and remove the gloss finish. Keep a light touch on the sand paper. You are only going to smooth out the marks, not create a depression in the wood.
Step 2: Iron the Railing
Since most woods swell when they are heated and have moisture added to them, you will be able to remove the bite marks by using this natural property. Use a damp washcloth and place it over the bite marks. Then place a hot iron on top of the cloth. Make sure the iron is on the highest setting without any steam on.
Step 3: Steam the Railing
As the iron rests on the wet cloth, it will create its own steam, that will cause the wood on the railing to swell. This swelling will fill in the small bite marks. Do not keep the iron on the cloth for an extended period of time. Wait about 30 seconds and remove the iron.
Step 4: Continue Steaming
This method will work to swell up the wood in the bite marks. However, it may take some time to get the wood to the original level. Continue with the steaming process along the length of the railing until the bite marks are removed.
Step 5: Stain Railing
Most of the time, it is very easy to find the right color stain to blend in with the rest of the crib. Once you have located the right stain, rub a small amount into the area where the bite marks were. You do not need a lot, and are only trying to blend in a small amount to match the overall look.
Step 6: Install Plastic Guard
Since prevention is the best form of maintenance, purchase a plastic rail guard that you can install over the wood itself. This will not only protect the wood from the baby, but also the baby from the wood. Some times, toxins or bits of wood, can cause severe reactions in the baby, if they are using the railing as a teething toy.
