Login Error
Close
How to Remove Blue Mineral Toilet Bowl Stains
by DoItYourself Staff
what you'll need
  • Baking soda
  • Bristle brush
  • Soda pop
  • Lime remover
If you've recently found yourself troubled by blue mineral toilet bowl stains, you're no doubt wondering how to get rid of them. Well, you'll be pleased to learn that removing blue mineral toilet bowl stains can be a very simple procedure if you're armed with the right set of instructions. Read on to learn everything you'll need to know.
Step 1 - Apply Your Baking Soda
Begin this process by covering your toilet bowl stains with baking soda, although lime remover should work just as well. After giving the baking soda a few minutes to sit, use your bristle brush to give the freshly-covered stains a vigorous scrubbing. If the stains have been removed from your toilet bowl, you'll all finished. However, should the stains prove stubborn, proceed with the next step.
Step 2 - Apply Your Cola
If baking soda didn't do the trick, you may be able to lay waste to your toilet bowl stains with nothing more than soda pop. Start this step by pouring roughly a can's worth of cola into the stained toilet bowl. After giving it ample time to fizz up, use your bristle brush to once again thoroughly scrub the stained areas. With any luck, your blue mineral toilet bowl stains should be no more.
 forum activity
