Login Error
Close
How to Remove Calcium Buildup in Pipes
by DoItYourself Staff
what you'll need
  • Water softener system
  • Water filtration system
  • Vinegar
  • CLR or any similar product
Calcium buildup in the water pipes can cause a lot of inconvenience and trouble. Calcium deposits inside the pipes result in slow drains and lead to a lot of inconvenience during the winter months, especially because these buildups cause the hot water within the pipes to run cold. Apart from that, other plumbing problems, like clogged shower heads and damaged pipes, can result from calcium deposits piling up in the pipes. It is important to keep the water pipes clog-free. Calcium deposits are found where mineral-based water runs through the local water system. In regions where hard water is used, it becomes mandatory to clean the pipes at a scheduled period of every three to six months.  Here is how to remove calcium buildup in pipes.
Step 1: Switching off the Main Water Supply
Before beginning the procedure of cleaning the pipes, it is imperative to turn the water supply off. This should be done using the main supply tap, which is often found in the bathroom or where the washing machine resides.
Step 2: Creating a CLR Mixture with Water
Mix CLR in water, reaching a 50/50 solution mix. Flush the solution through the pipes carefully. While using any sort of harsh chemical to clean the water pipes, it should be made sure that the water doesn't flow to a reservoir/storage of water, as the chemical can contaminate the potable water.
Step 3: Using Natural Agents Like Vinegar
Vinegar makes for an excellent alternative to strong or harsh chemicals since it is seen to be equally effective without having the same negative impact on the surrounding water reservoirs or posing any threat of ecological damage. Instead of any chemicals, white vinegar can be flushed through the pipes. White vinegar is known for dissolving the calcium build up.
Step 4: Removing All Dirt and Unwanted Materials from the Plumbing
Clean the plumbing outlets like the shower heads and faucets to remove the calcium deposited there. Keep the detached fixtures soaked in the cleaning solution for a few hours to ensure a satisfactory and proper cleaning.
Step 5: Employing the Use of a Water Softener System
The fifth step in the process of removing calcium buildup from pipes is to use a water filtration/softener system. A filtration system that uses reverse osmosis or a method similar can be a perfect solution to the problem of calcium deposits in hard water. The downside of this practice is that it is the most expensive solution of dealing with the problem in the long run. Similarly, a water softener system is another very expensive way to deal with the problem. However, if one can afford the costs, it can be a very effective solution.
 forum activity
