How to Remove Dye from Vinyl Upholstery
what you'll need
- Oil-free liquid dishwasher soap
- Clean bucket
- Warm water
- Distilled white vinegar
- Lint-free cloth
- Towel
- Empty spray bottle
- Funnel
- Tablespoon
- Measuring cup
Vinyl is a strong material that can withstand a lot of abuse. You will find that vinyl is used in many applications from, car seats to clothing and tablecloths. It is fairly inexpensive and will resist staining, cracking and tearing. Some materials, such as hair dye, can stain vinyl if it is allowed to dry. This can be very unsightly, but do not worry because dye can be removed without damaging the vinyl. It is very easy to remove dye from vinyl using many household products that are not only safe for the vinyl but also safe for the environment. The article that follows will show you how to make a cleaner that will not only remove dye from vinyl but will also not destroy it.
Step 1 – Make the Vinyl Cleaner
The first step in cleaning dye off of vinyl is to create a solution that is safe to use. The solution needs to be safe for the vinyl as well as for the environment. The vinyl cleaner is very easy to make with products found in nearly every home. Make sure you are using a clean bucket or bowl. Measure out one tablespoon of the oil-free dishwasher soap and add it to the bucket or bowl. The dishwasher soap should be oil-free in order to prevent residue from appearing on the vinyl. Add to the bowl two cups of warm water and one tablespoon of distilled white vinegar. Stir the solution until suds form. Open the spray bottle and inert the funnel and fill the spray bottle with the vinyl cleaner.
Step 2 – Treat the Vinyl
Before you spray down the vinyl, you should always wipe it down with a soft cloth. You want to remove any dirt or dust that may have accumulated. This is done so that the dirt doesn't essentially become mud and stain the vinyl even more. Once the vinyl is dusted off, spray it with the cleaning solution. There is no such thing as too much solution on the vinyl. Keep in mind, however, what the vinyl is covering. If it is a vinyl seat, then use less cleaner because you do not want the moisture making its way into the cushion.
Step 3 – Remove the Stain
Allow the vinyl cleaner to rest on the dye stain for several minutes. If the stain is particularly bad, then you may want to allow it to work for longer than a few minutes. When you think that enough time has passed, you can use a lint-free towel to scrub the vinyl. You cannot scrub hard enough to damage the vinyl, and dye is one of those chemicals that will adhere to the material. Wipe the vinyl down and inspect it for any dye that may be left behind. If more dye still remains, repeat this step.
