How to Remove Excess Duct Tape Sticky Residue
what you'll need
- Cloths
- WD-40
- Acetone solution
- Vegetable oil
- Putty knife
- Water
- Bucket
- Gloves
As useful as duct tape can be, it can be equally annoying when you need to remove it and it leaves a sticky residue in it's wake. Following a few steps will allow you to remove the residue effectively.
Step 1 – Inspection
Begin by examining the full extent of the problem so that you can get an idea of the volume of material needed to remove it. This process will also enable you to take a note of the material that is affected by the duct tape residue. This is necessary as the method of removal will differ according to the item you are working on.
Step 2 – Plastic
Duct tape residue should be relatively easy to remove from plastic items by immersing the item in water for at least 15 minutes. If the item is too large or not suited to being immersed in water, saturate a cloth in water and lay this on the site of the residue. This process should be sufficient to soften the glue and allow you to wipe it away with a cloth. In the event that traces still remain after the process ahs been complete, apply a little vegetable oil to a cloth and rub this over the site. Avoid rubbing back and forth for the sake of repeatedly wipe the cloth in a single direction.
Step 3 – Wood
Apply some vegetable oil to any duct tape residue that has affected wood. With varnished wood, cover the residue and allow the oil to sit in place for a few minutes. Once the oil has been allowed to penetrate the glue, you should be able to wipe it away with a cloth. Untreated wood can be wiped with a cloth that has been dampened with a little oil. If this does not work, use some glue removing solution such as acetone, which is available at hardware stores. Ensure that the area in which you are working is well ventilated ad follow the instructions carefully.
Step 4 – Glass
The look of glass and mirrors can be spoilt by duct tape residue so begin by removing the excess by gently scraping it with the tip of a putty knife. You will then be in a position to dampen a cloth with a little acetone and gently rub the surface to remove the remaining glue. Once the glue is removed, follow up by wiping the surface with a water dampened cloth to remove any traces of the glue removing solution.
Step 5 – Carpet
You will need to use WD-40 on any glue residue that has been left on carpets or rugs. Spray it onto the entire extent of the deposit and leave it to soak for a few minutes. Follow this up by applying some carpet shampoo over the treated area in accordance with the instructions. After it has been properly applied and left to dry, vacuum the affected area.
