How to Remove Faucet Handles
what you'll need
- Flathead or Phillips screwdriver
- Rags
- New faucet handle (optional)
- Padded pliers
- Utility knife
You may find yourself wanting to replace a faucet handle, to go with a new design option. A faucet handle can also become dirty inside or break and cause leaks, which can lead to costly damage. It is a good idea to remove faucet handles every couple of months for a good cleaning. Regardless of your reasons, this article will show you how to easily remove faucet handles.
Step 1 – Locate the Screws
Faucet handles are connected to the sink or shower by screws. Regardless of the type of screw, they are usually hidden. If it is a knob, look along the sides. There will be small screws inset within the material. They may also be located near the base where the knob is sitting. If the faucet handle is long and is lifted up or down (and even twisted in some instances), then the screws are very well hidden. Look on the base of the faucet handle for a logo of some sort. This is typically a sticker or emblem covering the screws. Use the utility knife to pry this off the faucet in order to expose the screws. Some knob styles will also have the screws covered by an emblem at the center of the knob. The emblem is removed in the same fashion, using a utility knife to pry it off.
Step 2 – Remove the Screws
Removing the screws on the faucet handle is relatively easy. Simply insert the corresponding screwdriver into the hole and grip the head of the screw. Turn the screwdriver counterclockwise to loosen the screw. Continue turning the screw until it falls limp and then simply lift it out of the hole. On older faucets, the screws may be rusty or covered in thick grime, making them difficult to remove. If this is the case, you will be tempted to use more force to remove the screw but this can cause a valve to break. In order to properly remove a stuck screw you will need to use a solvent. If there is a buildup of grime and oil then use a general degreaser on a rag to wipe away grime then try again to remove it. If the screw is rusted, apply penetrating oil, leave it on the screw for 20-minutes and then try again. You may need to leave the penetrating on the screw for up to a day.
Step 3 – Remove the Faucet Handle
Removal of the actual faucet handle varies from manufacturer to manufacturer. First, try to pull straight up on the faucet handle. On older faucets, removing the screw is enough to remove the handle and pulling up on it will do so. Other faucets have small pins under the screws. Grip the pin and pull straight up and the faucet handle can then be removed. Other pins require you to pull straight up and then turn clockwise. You can then remove the faucet handle. Clean up any water that came out and commence with your work.
