How to Remove Grease Stains from Clothing
what you'll need
- Tissue
- Blunt knife
- Corn starch
- Talcum powder
- Baking soda
- Dishwashing liquid
- Detergent
- WD-40
- Water
- Shampoo
- Shout stain remover
- Oxiclean stain remover
It is not easy to remove grease stains from clothing. Whether it is from the car, food or any other source, grease stains are common occurrences. With the right materials and methods, you can tackle grease stains effectively, whether they are new or old.
Step 1 – Test the Cleaning Material on an Inconspicuous Part
If you are dealing with delicate or expensive clothing, you must be very careful about the cleaner you use. Follow label instructions carefully. If the garment is marked as dry clean only, you must get professional help to remove the grease stain. Some of the best materials for removing grease stains are dishwashing liquid, corn starch, talcum powder, baking soda and, in tough situations, WD-40. Before applying any such products on to the clothing, you must first test it on an inconspicuous part. If there are any adverse reactions, do not use that product on the clothing.
Step 2 – Blot out the Excess Grease
By blotting out the excess grease beforehand, you will have an easier time cleaning it. Gently press a piece of tissue on the stain and repeat the process till the tissue comes off clean. Another alternative is to put some corn starch or talcum powder on the greasy part. If needed, rub the powder in very lightly. Leave the powder on for a few hours and then remove it. If there is more grease remaining, repeat the process again.
Step 3 – Scrap off Hardened Grease
Sometimes, grease stains can set in place and harden. In such cases, use a blunt knife to scrape off the built up grease. Be careful not to tear or damage the cloth in any way.
Step 4 – If the Stain Is New, Soak It in Warm Soap Water
New grease stains can be tackled with relative ease. After removing the excess grease, dip the stained area in warm water. Then, rub some detergent or dishwashing liquid on the stain. Dishwashing liquids are very effective, because they are meant to cut grease. Leave the soapy liquid on the stain for some time. After this, clean the clothing as usual. Avoid using the dryer and air dry the clothing instead. If there is any stain remaining, the heat of the dryer will set the stain and it will be very difficult to remove later.
Step 5 – If the Stain Is Old, Use WD-40
An old grease stain may be difficult to remove. In such cases, apply a small amount of WD-40 on the affected area. After this, you can treat the grease with some shampoo or dishwashing liquid. If needed, treat the stain with a commercial product such as Shout or Oxiclean and then clean the clothing as usual. In most cases, this will effectively get rid of the stain. Avoid ironing the clothing or putting it in the dryer until the stain has completely disappeared.
