Login Error
Close
How to Remove Lipstick Stains from Silk
by DoItYourself Staff
what you'll need
  • Masking Tape
  • Makeup remover
  • Talcum powder
  • Corn flour
  • Dry cleaning solvent
  • Spot remover
If you have tried to remove lipstick stains from clothing or other materials, you may find that this is not an easy task. Lipstick is formulated as a stain to last a long time. Though this is good for your lips, it is not an attractive option for clothing. This is even truer for silk, which is a delicate, expensive fabric that needs maximum care. If you get a lipstick stain on a silk garment or scarf, you do not have to spend a lot of money on dry cleaning. Try the below steps to remove the stain.
Step 1 – Test on an Inconspicuous Area First
Before using any of the below methods for stain removal, you must test it on an inconspicuous part of the garment. If there is any sign of discoloration or damage, avoid using that method. If you are unsure about trying to remove the stain yourself or if the garment is highly expensive, a better bet is to use a dry cleaner. Point out the stain and explain that it is from lipstick.
Step 2 – Apply Transparent Tape or Masking Tape
Try to attend to the stain as soon as possible. Otherwise, the lipstick will be absorbed by the fabric and will be difficult to remove. First, apply a piece of masking tape or transparent tape over the lipstick stain and smooth it down. Then rip it off. Most of the stain should have come off now. If it has not, repeat the step a couple of times. If this does not work, you can go to the next step.
Step 3 – Try Makeup Remover
Makeup remover is quite effective at removing lipstick stains. However, you must ensure that it is safe for your particular garment. Dab on some of the product in an inconspicuous area first and check to see any signs of damage. If it looks alright, you can try applying some on the lipstick stain. You can remove any remnants with talcum powder.
Step 4 – Dab with Talcum Powder
Dab the lipstick stain with some talcum powder or corn flour. The remnants of the lipstick will most probably be absorbed by the powder. Dab the powder and rub it in lightly. Remove the powder and inspect the area. If needed, repeat the step. Go to the next step if there is some stain remaining still.
Step 5 – Apply Dry Cleaning Solvent
With a soft cloth, dab some dry cleaning solvent such as K2R. Follow up with a dry spotter such as Kleenrite to dab the affected area. Repeat if necessary. Wash the affected area with cold water and repeat till the stain comes out.
Step 6 – Air Dry the Garment
After you follow the above steps, most of the stain will appear to have disappeared. However, you must not dry the garment in a dryer, because the heat will set any remnants of the stain that may not be visible when the garment is wet. Similarly, do not iron the garment till the stain has come off completely.
 forum activity
