Login Error
Close
How to Remove Permanent Marker from Tile
by DoItYourself Staff
what you'll need
  • Dry erase marker and eraser
  • Hairspray
  • Cloth
  • Magic eraser
  • Toothpaste and toothbrush
  • Acetone nail polish remover
If you have young kids at home, permanent marker stains are never a surprise. Kids will use your tile floor to learn art and craft tricks. There are a few things you can try to remove the permanent marker spots, without taking any professional help or replacing the tiles. Here is a basic removal option.
Step 1: Marking Over the Permanent Marker
If the spot is not very old and dark, you can use the dry erase marker to mark over where the permanent marker spot is. Ensure you do this thoroughly without leaving any trace of the permanent markings uncovered. Next, clear the tile using the dry erase eraser. Erase over the markings. This should leave the title clean.
Step 2: Repeat
If the permanent marker doesn't come off completely, repeat the process until the tile is completely clear.
If you get a clear tile, you do not need to follow the below mentioned steps. However, if the stains are old or are very dark, you will need to follow the following steps.
Step 3: Toothpaste and Brush
Next, you will need to use toothbrush and toothpaste. It is best to use one with old and hard bristles. First, apply toothpaste to the tile generously and try brushing off the permanent marker. You will need to exercise patience and work methodically. Next, wet a soft old cloth and use it to wipe the tile. Toothpaste contains a bleaching agent that should help to remove the stain.
Step 4: Hair Spray and Magic Eraser
If you still have markings after trying toothpaste, use hairspray. Aim the spray directly at the marking. Leave for a few minutes and allow it to sit. Then, wipe it down using a damp cloth. If the hairspray did not work completely, you will need to use a Magic Eraser. They can be found at your local home improvement store. Magic erasers are effective and expensive. Most people try everything only if the other solutions do not work. Rub the Magic Eraser on the stain, until it is gone.
Step 5: Polish Remover
Nail polish remover is the last option you want to use. Even if all other forms of treatment fail, take a moment to consider the abrasive effects of the polish on the tile. Use caution, especially when the remover is based on acetone, because it can easily peel off the covering of most tiles or disfigure the coloring. Apply the polish remover over the area with the permanent marker. Once you are finished, wipe it down completely with a wet cloth.
If the stain remains, you will need to consult a professional. They may suggest you to get the tile replaced because the stain may never be removed. Replacing the tile completely is not difficult to do. You will need to match up the tile, removing the existing tile and put in a new one. This should be the last resort because a new tile will usually look a little different than the rest of your tiles.
 forum activity
