Login Error
Close
How to Remove Scratches on Formica
by DoItYourself Staff
what you'll need
  • Paste wax
  • Liquid formica filler
  • Wood putty
  • Putty knife
  • Steel wool
  • Spray wax (like Pledge)
  • Rag
  • Soapy water
Formica is a fairly inexpensive type of surface used for kitchen and bathroom counter tops. However, it is prone to scratching. Once scratched, it begins to look worn and tired. If you are not in the market for a new counter top or if your budget cannot support it, try to remove the scratches by following a few easy steps. The goal of the project is to restore the Formica surface, make it look as close to new again as possible, and have it shine brightly and confidently in your room space.
Step 1 - Clean and Clear the Formica Surface
Completely clear your counter tops of all items stored on the surface. This includes any dishes, liquid soap bottles, cloths, appliances or soap dishes. Put the items up in a cupboard or in another room while you complete this project. Second, take out a gentle rag and fill a sink or your laundry tub with a warm soapy water. Using a gentle rag, wipe the surface of your countertop. Scrub any caked on dirt and get as much grime as you can out of the crevices of your counter top scratches.
Step 2 - Rub Paste Wax and Buff
Purchase paste wax at a hardware store or home improvement center. You may also consider using an automotive wax product.
Take a small amount of paste way and rub it into the scratch on the Formica surface. Work as much of the wax as you can into the scratch. The wax should fill the scratch completely. Using a clean buffing cloth, buff the surface of the counter top, including the scratches you have just filled. At the very least, after you have completed this step, your small scratches will show a marked improvement in appearance.
Step 3 - Rub in Formica Filler
On larger scratches, use a Formica filler and rub it over the surface of the scratched areas. The Formica filler will help further seal the scratch and make it disappear. On extremely deep scratches, apply the filler using a putty knife. Allow the Formica filler about 24 hours to dry completely.
Step 4 - Buff Scratch with Steel Wool
After the filler has completely dried, begin to buff the scratches with steel wool. Gently take the steel wool and rub it onto the scratched surface. Use gentle circular strokes. Avoid using a lot of pressure, otherwise you may create additional, fresh and new scratches on your counter top from the steel wool application.
Step 5 - Clean Surface with Spray Wax Polish
After buffing the scratch with steel wool and making the surface perfectly smooth, use a spray wax polish like Pledge to clean the surface. Wipe clean with a rag and you can replace any items removed from the Formica.
Step 6 - Fill Your Counter Tops
Bring back all your counter top appliances, gadgets and materials. Place them back on your newly restored Formica counter top surface.
 forum activity
