Login Error
Close
How to Remove Shrubs
by DoItYourself Staff
what you'll need
  • Shovel
  • Garden shears
  • Chain
  • Pickup truck
  • Rake
Removing shrubs is a simple process to learn, but a difficult one to carry out. The larger the shrubs are, the harder it becomes to follow the instructions laid out below. Before you begin, it's important to note that the instructions below only apply to shrubs that you intend to discard. If you would like to transplant the shrub, consult the tutorials on this website that cover transplanting.
Step 1 – Prepare Area
Careful planning is required for you to be able to remove the shrub with the least amount of damage being done to the rest of the area. Shrubs that are established will have root structures that go way down. Digging is too labor intensive in that case, so you need to yank the shrub out. Plan the route of the truck and plan the placement of the chain. If you need to, cut away some of the branches so that the chain can get a secure purchase around the entire shrub.
Step 2 – Place Chain
You want the chain to wrap around the bottom of the shrub, but not so low that it is touching the ground. Ideally, the chain will start close to the ground at the back of the shrub and then slowly come to the level of the back of the truck where the chain will be tied. This will place the maximum amount of torque for pulling the shrub out of the ground.
Step 3 – Tie Chain
Now that you have the chain wrapped around the shrub, attach the other end to the back of the truck. The fit should be snug.
Step 4 – Free Roots
Before you start driving the truck forward, dig around the back area of the shrub relative to the position of the truck. This should also be the area where the chain is lowest to the ground if you followed step 2 properly. Dig to free the roots at the back and then chop those roots and remove them as much as you possibly can.
Step 5 – Drive
Move the truck forward and pay close attention to what happens to the shrub. If it starts to be yanked out of the ground, you can continue moving the truck until it comes out. If it does not start to come out of the ground, you need to repeat steps 4 and 5 a second time. Keep doing them until you get the shrub pulled out of the ground by moving the truck slowly forward.
Step 6 – Repair
Pulling the shrub out should have created a gaping hole in the ground. Use the shovel and rake to fill the hole in, flattening out the soil in the area as much as possible. With that step accomplished, you have successfully removed the shrub.
 forum activity
