How to Remove Silicone Adhesives from Glass
what you'll need
- Safety goggles
- Protective gloves
- Breathing mask
- Putty knife
- Silicone solvent
- Sponge
- Washcloth
- Mild liquid soap
If silicone adhesive has leaked onto any of your home's glass surfaces, you may be wondering how to go about removing it. With the proper set of tools and a helpful instructional guide, you can purge silicone adhesive from your glass surfaces in a timely and stress-free fashion.
Step 1 - Protect Yourself
If something goes wrong when you're performing this task, you may have to contend with bits of flying glass. So before beginning the adhesive removal process, don a pair of safety goggles, a breathing mask and a pair of protective gloves. Additionally, make sure the area in which you are performing the task is well-ventilated, as the fumes given off by silicone solvent can be quite potent.
Step 2 - Apply Your Solvent
Having taken the necessary precautions, you're ready to carry out the adhesive removal process. Begin this step by applying your silicone solvent to any silicone adhesive deposits on your glass. You'll now need to allow the solvent to set in for the amount of time specified on the product's packaging.
Step 3 - Apply Your Finishing Touches
Once your silicone solvent has been given ample time to sit, use your putty knife to gently scrape away any remaining silicone adhesive. When performing this step, take your time. Haphazardly scraping the leftover adhesive is liable to result in broken glass. Use a sponge or washcloth dampened in mild liquid soap and warm water to give the glass a vigorous cleaning, after which you'll need to rinse off the makeshift cleaning solution with warm water.
