Login Error
Close
How to Remove Silicone Caulk from Wood
by DoItYourself Staff
what you'll need
  • Sharp razor blade
  • Nose pliers/tweezers
  • Heat gun/hair dryer
  • Silicone caulk remover (McKanica Silicone Caulk Remover Gel)
  • Damp cloth/rag
  • Wood cleaner (Murphys Oil Soap)
There are many uses for silicone caulk in our homes; however, when it comes to removal, silicone caulking can be the trickiest caulking to remove. Silicone caulking can be used as a weather sealant, an adhesive, and to fill in joints and gaps, so you will most likely find it on wood surfaces, tiles, and such. Removing silicone caulking from wood requires precision and caution, but it can be done. Keep in mind that using a screwdriver or a chisel to remove or scrape the caulking is ineffective and can even damage your wood surface.
Step 1 – Preliminary Check
Before you begin removing the silicone caulking, you should do a spot test with the silicone caulk remover on the wood. This is to ensure that the remover does not damage your wood. Also, if you are removing the caulking from a joint, where the caulking was used as a sealant, do check if there is a backer rod under the silicone caulk. The backer rod should also be removed with the silicone caulk, especially if you are re-sealing the joint.
Step 2 – Remove Loose Caulk
If the silicone caulk is old, there will be loose bits of caulking. These can be removed with your hands. Scrape the area with your finger, and pull off any loose bits.
Step 3 – Heat the Caulk
Once you have made sure that there are no loose bits of caulking, use the heat gun or hair dryer to heat the caulk; heating the caulking helps to soften it for removal. Be careful not to overheat the area as it may damage the finish on the surrounding wood surface.
Step 4 – Remove Remaining Caulk
When the caulking is sufficiently heated and soft, use the razor blade to carefully scrape or slice the caulking. It is important to keep the angle of the blade low; this prevents the blade from scratching the wood underneath. Also, be careful when working with the razor as it is very sharp. Most of the caulking will slowly begin to come off in large threads or flaps. Hold the ends using your hands, pliers, or tweezers, depending on the size and thickness of the caulking, and pull it off. You should be able to remove almost all of the remaining caulking in this step.
Step 5 – Use the Silicone Caulk Remover
Since silicone works as an adhesive, there will some caulking residue left behind on the wood even after you have removed most of it. To clean out this residue, apply the caulk remover to the caulking, and then clean using the damp cloth. Be careful not to wet the cloth too much as this may damage the wood.
Step 6 – Finishing
In order to ensure that the wood remains clean and damage-free, finish by applying a wood cleaner to the wood surface. If you intend to re-paint, apply a primer (Kilz) to the surface to prep it for a paint job.
 forum activity
