Login Error
Close
How to Remove the Stain from Your Wood Deck
by DoItYourself Staff
what you'll need
  • Commercial deck stripper
  • Broom
  • Stiff bristled brush
  • Garden hose
  • Power washer (optional)
  • Orbital sander
  • Dust mask
  • Flat vibrating plate sander
  • Backer pads
  • Sandpaper sheets - 80 grade
  • Palm sander
  • Knee pads (optional)
  • Shop vac
  • Garden hose (optional)
Removing the stain from your wood deck may become necessary if it has become sun bleached and weather worn. Dull looking decks can be made almost new again by removing the old stain and replacing it. There are two methods you can use to accomplish this. Choose the stain stripper method if your wood is in good condition and doesn't have thick layers of finish to remove. Opt for the sanding method if you have multiple thick coats to penetrate or the wood needs extra smoothing.
Stain Stripper Method
Step 1 - Prepare and Apply Stain Stripper
Sweep away all dirt and debris from the deck to obtain a clean surface. Apply a generous amount of commercial stain stripper with a brush, roller or hand sprayer until the entire surface is covered. Wait the recommended amount of time for stripper to begin lifting the old stain.
Step 2 - Remove Stain
Use a stiff bristled brush to scrub the wood along the grain to remove the lifted stain. Take care to get into corners and other small areas.
Step 3 - Rinse
Use a garden hose to rinse off stain stripper with a large amount of water. Use a power washer if extra cleaning is needed. Allow deck to dry thoroughly for 3 to 4 days.
Step 4 - Sand
Use an orbital sander to remove any remaining stain and sand down any rough spots. Make sure you wear a dust mask while sanding.
Step 5 - Finish Up
Sweep or vacuum up any dust left from sanding to insure a clean surface. You're now ready to apply a new stain or paint of your choice.
Sanding Only Method
Step 1 - Preparation
Start by vacuuming your deck thoroughly to make sure it's clean of dirt and debris. Make sure the deck is completely dry before beginning any sanding.
Step 2 - Sand the Deck
Rent a flat vibrating plate sander from your local tool rental. Purchase backer pads and 80 grade sandpaper sheets for a smooth finish that will accept new paint or stain better. Wear a dust mask while sanding. Sand large areas of the deck with the vibrating plate sander, using a back and forth, side to side motion.
When the main area of the deck is sanded smooth and all stain is removed, use the palm sander to sand the edges, rails and steps. You may want to wear knee pads for comfort.
Step 3 - Finish Up
Use a shop vac to vacuum up all the sanding dust from the deck. You can wet the deck down with a garden hose if desired, to make sure all dust is removed. Allow deck to dry thoroughly for several days before refinishing if you use water.
When you need to remove stain from a wood deck, weigh your options and consider the amount of time, work and expense that will be required. Either of these methods will result in a stain-free deck that can be refurbished with your choice of stain or paint, bringing new life to your old deck.
 forum activity
