Login Error
Close
How To Remove Tin Ceiling Panels
by DoItYourself Staff
what you'll need
  • Crowbar
  • Ladder
  • Plastic sheets
  • Protective gloves
  • Protective goggles
  • Protective mask
  • Screwdriver set
  • Strapping tap
  • Tarps
  • Painters tape
  • Touch up paint
  • Paint brush
The use of tin ceiling panels became popular during the Victorian era. Ornate, opulent ceiling designs, previously created by European plaster artists, could be recreated inexpensively with rolled tin plate. The material is most likely old or they no longer suit the décor you have chosen. There are many reasons to remove these tin ceiling panels. Call a local salvage company if you wish to sell the panels. Often times these people will remove the tiles in exchange for a reduced price for the salvage. Alternatively, remove them yourself with a few tools and follow a few simple precautions.
Step 1 – Prepare the Room
Tin ceiling tiles were popular many years ago; chances are they have been on that ceiling a long time. Great care and caution is required when removing these panels. Take everything out of the immediate area. Furniture, picture frames on the walls, drapes and blinds should be removed. Wall to wall carpeting should be covered with heavy plastic and taped down around the edges.  Use painter tape to cover any moldings that may be damaged with the sharp edges of the removed tin panels. You can add a layer of duct tape to the painters tape for extra protection; however, do not place the duct tape directly on the molding. Turn off the electricity at the breaker and remove any mounted light fixtures.
Step 2 – Remove Cornices
That beautiful crown type molding around the end of the ceiling, referred to as a cornice, is your beginning point. These generally come in pieces 48 inches long. Find a seam in the cornice and begin there. The cornice originally was overlapped; this may have separated over the years. Once you find the first seam follow the cornice to the next seam to see if it overlaps or under laps the next piece. You want to remove the first under lapping cornice. This will make the removal of the next piece easier. Use the crow bar and lift the edge of the cornice. Remove all the cornice from the ceiling.
Step 3 – Remove the Tin Ceiling Panels
Locate the seams of the tin panels. The best place to start is by removing a panel closest to a wall and work your way out from there. Tin paneling is installed by attaching it to a 1 x 2 inch wood ceiling anchor. Locate the nails and pry the tile away from the wood anchor. Once the tin gives way of the first row of nails you will be able to manually pull on the panel and the nails will slip out. Assist any stubborn nails with the crow bar.
Precautions
Tin paneling will be very flimsy when removed and the edges will be very sharp. Take caution that the corners of the paneling do not cut the walls or molding in the room.  Always wear your protective gloves and goggles. Another precaution to consider is that tin ceiling panels may have been painted and there is a good chance lead based paint was used.  Make sure your protective equipment is compatible with this type of work.
 forum activity
