Login Error
Close
How to Repair a Cracked Concrete Planter
by DoItYourself Staff
what you'll need
  • Mortar
  • concrete sealant
  • brush
  • cloth strips
  • trowel
  • putty knife
A concrete planter is a very popular feature in most gardens. They are preferred not only for their decorative use; planters are functional as well. Even if weather is rough, these devices do not easily break or crack. They may crack only when they fall or when the roots of a plant cause the soil to expand. If a concrete planter does break, it is less expensive to have it repaired than to buy a new one. Here’s how it is done.
 Step 1–Empty the Concrete Planter
Remove the contents of the planter and transfer to a temporary container. After that, flush any debris that may be left inside it by spraying water.
Step 2–Scrub the Crack
Use a rough brush to scrub the surface of the crack and remove any loose concrete that is trapped inside. If the concrete planter has large cracked pieces, clean them as well. Make sure to remove any loose pieces as much as possible in order to ensure that they do not get in the way during the gluing process. The best way to repair the crack is to glue it back together so make sure that the surfaces of the cracked pieces are free from loose concrete.
Step 3–Apply Mortar
Apply mortar to act as glue and seal the crack. Make sure you apply a thick layer of mortar on the crack to put the pieces back together. Apply a sufficient amount so as to cover the crack/s completely. Use a putty knife to drive the mortar inside the cracks if a trowel is not sufficient for the purpose. Make certain that every gap in the crack is covered with mortar. Push the cracked pieces together and ensure they are placed securely back into the concrete planter form.
 Step 4–Wrap the Planter with Cloth Strips
Dampen the cloth strips before wrapping them around the concrete planter. The strips should be wrapped as tightly as possible to hold the broken pieces together. Wrap the cloth strips several times to completely cover the glued pieces. If cloth strips are not available, make use of other alternatives, such as duct tape. Allow the mortar to dry. Check the information on the mortar to find out how long it takes to dry. Usually, it will take around 24 hours.
Step 5–Remove the Cloth Strips
Remove the cloth strips or duct tape after the recommended time that it takes the mortar to dry. Check if the crack is sealed back together completely.
Step 6–Apply Sealant
Apply concrete sealant on the concrete planter in order to protect it from the damaging effects of external elements.
Step 7–Allow the Planter to Dry Completely
Do not use the concrete planter yet. It is better to let it dry for at least a week in order to ensure that the crack has completely cured.
 forum activity
