How to Repair a Dented a Drywall Bullnose Corner Bead
what you'll need
- Drywall taping knifes
- Hammer
- Drill or screwdriver
- Drywall screws (if needed)
- Drywall mud
- Mud pan
- Sandpaper
- Rag
- Texture (optional)
- Paint (optional)
You can protect the corners of your house from damage by installing a drywall bullnose corner bead. However, what happens if the drywall bullnose corner bead becomes dented? It becomes a very simple solution by removing the drywall from the bullnose corner bead and straightening it out with a hammer. Here are 9 simple steps to repair a dented drywall bullnose corner bead.
Step 1: Clear away the Old Drywall
Expose the bullnose corner bead by scraping the drywall around it with a drywall taping knife. Make sure to scrape the drywall from both sides. Finish by removing any loose pieces of drywall near the bullnose corner bead.
Step 2: Hammer the Dent
Repair the dent by gently hammering the drywall bullnose corner bead until it is straight.
Step 3: Check the Screws
If any of the drywall screws in the bullnose corner bead appear to be loose, make sure to tighten them. If the drywall bullnose corner bead needs additional reinforcement or support, add more drywall screws.
Step 4: Prepare Drywall Mud
Prepare the drywall mud for use and fill the mud pan.
Step 5: Repair Drywall
Spread the drywall mud to the bullnose corner bead with a drywall taping knife. Apply the mud by first spreading it at the bottom and moving up. Then spread it on with a downward stroke to create a sharp corner. Make sure that the mud is level with the rest of the wall. Allow time for the mud to dry before continuing.
Step 6: Apply a Second Coat of Drywall Mud
Using the same method as before, add a second coat of drywall mud. Let the mud sit for a few minutes to dry.
Step 7: Sand the Drywall
To rebuild the original shape of the wall, you’ll need to sand the drywall to match the rest of the wall. Using circular motions, sand the wall until it is smooth and blends with the rest of the wall. Avoid using up and down motions or you will create flat areas.
Step 8: Blend Edges of the Repair
Blend the drywall with the previous drywall by wiping it down with a damp rag.
Step 9 (Optional): Texture and Paint the New Drywall
If your walls are textured, apply texture to the new drywall so that it matches the rest of the wall. Finish up by painting the new drywall with the same color as the original, if necessary.
Repairing a dent in your drywall bullnose corner bead does not need to be a difficult task. By following this simple guide you can save yourself money, in addition to making your walls look better.
