Login Error
Close
How to Repair a Dishwasher Door Gasket
by DoItYourself Staff
what you'll need
  • Screwdrivers
  • Replacement gasket (potentially)
Inside a dishwasher, there is usually some water at the bottom to keep the dishwasher door gasket or seal moist. When you start your dishwasher, it drains this water out and fills it with clean, fresh water. The door has a gasket, which ensures that the door is sealed properly and no water will flow out of it when it is working.  The dishwasher door is prone to damage from rough usage and careless handling. Over time, it will accumulate mold, dirt and grease causing the door gasket or seal, springs and hinges to become damaged and less efficient. The door gasket can crack or become hard if it is not used frequently. This is because the standing water inside the dishwasher will evaporate after long disuse and the seals will dry up. The heat inside the dishwasher can also cause the same results. Sometimes, they may even break. If your dishwasher has a pool of water in front of it, a damaged door gasket is most probably the cause. Follow the following steps below to diagnose the extent to which your door gasket is affected and how to repair it.
Step 1 - Turn off Power
Safety is very important in all matters, especially when the work involves electrical appliances. Make sure that the dishwasher is unplugged, not only switched off, to avoid mishaps. Also, check that there are no other electrical cables or the like lying around or in the pool of water in front of the dishwasher.
Step 2 - Inspect the Door Gasket
Open the door of the dishwasher and pass you hand over the gasket or seal in the door. It should feel pliant, smooth and even. If this is the case, go to Step 4. If it feels uneven, cracked or irregular in any part, go to Step 3.
Step 3 - Replace the Door Gasket
This kind of damage cannot be repaired and the door gasket has to be replaced. Trying to repair it will only be a waste of time and effort. Install the new one according to the instructions in its manual.
Step 4 - Check the Latch
Dishwashers usually have a latch that helps the door fit and seal properly against the cabinet. Close and latch the door and then slightly move it back and forth. If it moves, the latch is loose. This may be the reason why the seal does not compress against the cabinet. Tighten the latch gradually, checking the door to see if it is sealing properly. You can stop adjusting when you have the door sealed and secure.
Now, you may mop off that pool of water in front of your dishwasher.
 forum activity
