How to Repair a Leather Sofa in 6 Steps
what you'll need
- Leather repair kit comprising colorant to match furniture
- Replacement leather swatch
- Canvas backing patch
- Palette knife
- Fine sandpaper
- Rubbing alcohol
- Clean cloths
- Sharp scissors
- Tweezers
Being able to complete quality leather sofa repair can lessen the stress that comes from discovering damage to your sofa. Having knowledge of the easiest way to affect repair can be a useful skill. Here are 6 steps to repairing a sofa.
Step 1 – Select Leather Repair Kit
There are many quality leather repair kits on the market and you should choose one in accordance with the type and color of the leather you are repairing. The leather used for most sofas will have a coating that protects it, so ensure that the repair kit is suited to your sofa. Peruse the instructions before purchase to determine that the kit contains everything you need to do the job.
Step 2 – Assess the Damage
Inspect the repair site to determine whether you require a replacement leather patch. A tear in the leather will not require one, but a missing piece of leather will. If a replacement leather patch is required, check beneath the item of furniture to see if the manufacturer has attached a spare piece of leather. Alternatively, purchase some from a fabric shop.
Step 3 – Preparation
Begin the leather sofa repair by cleaning the site with the products contained in the repair kit. This will involve either rubbing the surface with sandpaper or a solvent, depending on the type of leather you have. Besides cleaning away any debris, this process will also remove the coating of the leather, which will enable you to access the leather properly. Finish the cleaning process by wiping the surface with rubbing alcohol. Where the edges of a tear are protruding outward, use sharp scissors or a knife to carefully cut them away until the repair is neat.
Step 4 – Insert Backing
Using a pair of tweezers, insert the canvas backing into the hole, holding one edge while pushing in the rest until it lays flat. Using a palette knife, apply a thin layer of adhesive to the edge of the leather between it and the canvas and press it down for a few minutes until it is dry.
Step 5 – Apply Filler or Patch
With the backing in place, you will be in a position to apply the filler or a patch. If the latter is required, use the palette knife to apply a thin layer of adhesive to the rear edge and put it in place–the patch should fit snugly. After this, the process is very similar. Apply a thin layer of filler to the hole and allow it to dry before applying another. Continue in this manner until the filler is at the same level as the existing leather.
Step 6 – Color and Seal
Apply the colorant to the leather sofa repair site, using an airbrush method to blend it in, if necessary. Allow each layer to dry before applying another. Apply the relevant coating to seal in the color and provide additional protection.
