How to Repair a Swamp Cooler Leak
what you'll need
- Pliers
- Wrench
- Wire Brush
- Screwdriver
- Acrylic Caulk
- Plastic Gloves
To repair swamp cooler leaks, you need to inspect various, probable causes of the leakage. Such possible sources of leakage in a swamp cooler and the appropriate measures to correct them are explained below.
Step 1—Getting Started
Wear a pair of plastic gloves. Remove the side panels of the cooler that contain the padding. Please note that you might need to switch-on the cooler repeatedly to diagnose the cause of the leakage. However, you should switch-off the cooler and unplug it at the time of executing the repair.
Step 2—Correcting Swamp Cooler Leakages Due to Loose Copper Lines
The copper line or the main water line carries water into the swamp cooler. This line is secured with a thick nut called a compression nut. Use a wrench to tighten the nut. Turn on the water supply. If water is still dripping from the nut, you need to check the washer. Shut-off the water supply. Disconnect the water line by loosening the compression nut. Inspect the inner surface of the compression nut and its washer. The washer should be replaced if it seems worn-out. The insides of compression nut might be lined with deposits formed by hard water. Use the tip of a screwdriver or a wire brush to remove the scaly deposits.
Step 3—Correcting Leaks along Bottom of Swamp Cooler
The reservoir tray is prone to developing cracks. To identify this problem, switch-on the cooler’s water supply. Now, see if water is escaping from the bottom of the cooler. Remember, coolers with reservoir tray cracks tend to empty rather quickly. Drain-out the remaining water from the cooler and repair the cracks. A few beads of an acrylic caulk can work efficiently in plugging the leakage. Another reason for water leaking from the bottom of the cooler can be a slack overflow pipe. Look to see if the pipe is properly positioned on to its drain hole. If not, use a pair of pliers to straighten and tighten the pipe.
Step 4—Correcting Swamp Cooler Leaks due to Leaky Pads
Leaks can be caused by the pads due to a variety of reasons. For starters, the pads should be properly fitted. Loose pads tend to deflect the water. Some swamp cooler models have a metallic mesh like structure to secure the padding. The mesh is secured along the inside of the side panels with screws. An unsteady mesh can cause the padding to protrude and cause severe splashing of water. Tighten the screws of the mesh with a screwdriver. Check the edges of the cooler’s body where the pads are inserted. These edges are often lined with deposits formed by hard water. Use a wire brush to scrape-off such deposits.
Step 5—Correcting Swamp Cooler Leaks due to Float Valve Problems
You need to ensure that the water in the cooler doesn’t overflow. This in turn depends on the functioning of the float valve. Ensure that the float valve arm is properly positioned. Sometimes the float valve is deflected towards the edge of the water reservoir. Tighten the nut securing the float valve with a wrench. The arms of the float should not be bent. If this is the case, you need to replace the float valve.
