How to Repair a Washing Machine that Is Noisy
what you'll need
- A screwdriver
- Your washing machine's owner's manual
- A pocket flashlight
- Replacement drum bearings
- A replacement driver belt
If your washer has recently started to make strange noises, you may be curious about the proper method to repair a washing machine. Although the task may seem a bit complex, you can repair a washing machine in a timely and stress-free fashion, particularly if you tackle the job with the proper guide and a good set of tools.
Step 1 - Check Your Washing Machine for Small Items
As strange as it may sound, many washing machine noises stem from small items that have fallen out of your clothing's pockets. These items typically include pocket change, pens, pencils, paperclips and pocket protectors. Carefully inspect your washing machine for any of the aforementioned items, as well as any other small items you may have forgotten to remove from your pockets. Depending on the quality of your laundry room's lighting, you may require the aid of a small flashlight to locate the wayward items. This is arguably the simplest way to repair a washing machine.
Step 2 - Make Sure Your Washing Machine is Sufficiently Balanced
Improperly balanced washers are another common cause of strange washing machine noises. Make sure that your washing machine's legs are perfectly balanced and that the device has not been placed on an uneven surface. This is another simple way to repair a washing machine you should try before opening up your washer or replacing any parts.
Step 3 - Check Your Washing Machine's Drum Bearings
If you're unable to locate any small items and have confirmed that your washer is properly balanced, the source of the noise may stem from your washing machine's drum bearings. Washing machine noise has been known to result from water finding its way into the device's drum bearings. Begin this step by making sure your washing machine is turned off and unplugged and that the device's water supply has been shut off. Once all the necessary disconnections have been made, use your screwdriver to remove the back end of your washing machine and locate its drive belt. You may need to incorporate the aid of your owner's manual to determine the belt's exact location. Next, remove the belt. Depending on the type of washing machine you own, you may be able to do this without the aid of any tools. Once the belt has been removed, use your hands to spin your washing machine's drum. If the spinning gives way to a rumbling noise, your drum bearings will need to be replaced. Once again, consult your owner's manual to determine the type of bearings your washing machine needs.
Step 4 - Replace Your Washing Machine's Driver Belt
If all else fails, the problem almost certainly lies with your washing machine's drive belt. Worn-out or damaged drive belts have a reputation for giving way to odd noises. Consult your owner's manual to determine the proper type of replacement belt, as well as the proper method for disconnection and replacement of the belt.
