Login Error
Close
How to Repair a Wireless Remote Light Switch
by DoItYourself Staff
what you'll need
  • Replacement Wireless Remote Light Switch
  • Screwdriver
  • Wire Cutter or Stripper
  • Electrician Tape
  • Electrical Current Tester
If you have a wireless remote light switch in your home that is not working properly, you will need to troubleshoot the switch to determine where the problem lies. In most every case, a faulty wireless remote light switch that is not working properly will need to be replaced in order to have your wireless remote control working properly. To determine if this is the case, you need to follow the steps in this article necessary to make the proper repair.
This do-it-yourself project requires that you to have some knowledge and familiarity with electricity. You should read any information before commencing with this project that you can find regarding light switch wiring if you are not familiar with how to wire a light switch. This will prevent you from becoming injured or electrocuted as a result of working with the electric switch and circuit.
Step 1: Troubleshoot the Wireless Remote Light Switch
Before you begin the repair of the wireless remote light switch, you need to troubleshoot to see where the problem lies. Point the remote to the wireless remote light switch control and see if any signal is being received. A low signal or nonexistent one can indicate
 forum activity
