Login Error
Close
How to Repair Awning Windows
by DoItYourself Staff
what you'll need
  • Damp cloth
  • Screwdriver
  • Window parts, depending on the actual problem
One of the unique features of awning windows is that they have 2 sets of hinges which enables them to open both ways: inward and outward. This is quite useful in the rainy areas as you can keep the windows open for air circulation and the water will slide off the panes. However, the moving parts of the window can get damaged quite often and hence need frequent repair. The good news is that repairing the window is not a very difficult job and you can do it yourself instead of calling a professional for it. Simply follow these steps to repair your awning window:
Step 1 – Identify the Problem
You need to identify the cause for window’s malfunctioning. It could be as visible as a broken pane and as hidden as window’s internal mechanism.
Step 2 – Look for Clues
Carefully open and close the window and look/listen for any clue to the problem.
Step 3 – Look for Inner Problems
Apart from broken pane, check for the proper working of all hinges, screws and braces separately.
Step 4 – Remove the Window
If you are not able to detect the problem, you need to remove the window. To do so, first of all take the screen off the awning window and disengage the operator arms.
Step 5 – Remove the Sash
Remove the sash. Do ensure that the window is not locked.
Step 6 – Access the Hidden Defective Parts
Now you will have the access to all the parts of the window, including the ones that were hidden earlier. Carefully test the internal mechanism of the window to look for defective parts.
Step 7 – Purchase the New Parts
After identifying what the problem is, order the relevant parts from the manufacturer or spare parts suppliers.
Step 8 – Type of Possible Parts
Depending on the problem you might need only minor parts such as the stretcher slips or you might require some integral parts such as crank lever, operator crank or a sash.
Step 9 – Install the New Parts
Now install the required parts. To remove the defective parts and install the new ones, follow the guidebooks of the window and the parts.
Step 10 – Test the Window
Test the window multiple times, including some rough testing such as opening and closing with a bit of force, to make sure that the window works properly.
Step 11 – Verify the Installation
If you still face problems with the window, just make sure that you have put back all the parts, which you removed during the process, properly and that the window’s mechanism is not facing any obstructions.
Step 12 – Clean the Window
It would be a good idea to clean all the parts with a damp cloth to remove any dust and other unwanted particles which may obstruct smooth movement of the hinges and the other parts of the window.
 forum activity
