Login Error
Close
How to Repair Cabinet Door Edges
by DoItYourself Staff
what you'll need
  • Hand Planer
  • Sander
  • Wood Putty
  • Screwdriver
  • Scrap Wood
  • String
  • Jig Saw
  • Wood Glue
  • Paint
There will come a time when a cabinet door will need some repair to the door itself. These repairs can be to the face of the door, the hinges or even the panel. At times, the edges of the door may need to the repaired to give it back its even lines and presentation.
Repairing your cabinet door edges requires a lot of patience and a steady hand. With some basic woodworking skills and tools, you will be able to restore you cabinet door to like new condition.
Step 1 - Remove Cabinet Door
With a screwdriver, unscrew the hinges from the cabinet face. Once the door is off the cabinet, you can then remove the hinges from the cabinet door.
Step 2 - Inspect Damage
You might just need to add some wood putty to the edge and smooth it out. At other times you will need to plane the wood, and cut of a piece of replacement wood. Find out exactly what you need to do before getting out the tools.
Step 3 - Plane Side of Wood
With the hand planer, scrape off the loose ends of wood and get a smooth, straight surface to work on.
Step 4 - Measure Gap
After you plane the wood you will have a gap from the top to the bottom of the cabinet door. Place the door on a flat surface and use a length of string to help you figure out the angle. Place the end of the string on the edge of the door that has the most material. Stretch it out in a straight line. Measure the distance from the top edge of the door to the string.
Step 5 - Cut Replacement Wood
Set your wood on the work table and transfer the dimensions onto it. Cut out the wood with a jig saw and sand it smooth.
Step 6 - Glue to Cabinet Door
Apply a bead of glue along the entire length of the cabinet door edge. Set the replacement piece on the cabinet and clamp together.
Step 7 - Sand off Glue
Once the glue has dried, use the sander to sand off the excess glue. Make it flush with the wood, without removing any more of the cabinet door surface.
Step 8 - Apply Putty
Apply wood putty along the seam or any gouges that did not come out during the planing process. Once the putty dries, you can sand it off to give the cabinet door a smooth surface.
Step 9 - Paint Cabinet Door
After the door has been sanded and wiped down, paint it with the color of the cabinet door.
 forum activity
