Login Error
Close
How to Repair Drywall
by DoItYourself Staff
what you'll need
  • Joint tape
  • Joint compound
  • Drywall paper
  • Joint knife Paint primer
  • Paintbrush
  • Paint
  • Utility knife
  • Hammer
  • Screwdriver
  • Sandpaper
  • Sanding block
It wouldn't be at all uncommon for you to find a need to repair drywall in your home that has been damaged or you may find an occasional protruding drywall nail head or screw head that will require attention. If you choose to repair these damaged places, you might need a few tips. Here are 4 steps that will be of help to you in repairing damaged drywall.
Step 1 – Fill Dents or Holes
If your dent is shallow—that is, if it is ½" or less in depth—you will be able to patch it using only joint compound. If it is deeper, or if you have a hole through the drywall, you will need to apply a patch over the damaged area. For a shallow dent, spread a layer of mud (joint compound) over the dent. Then, cut a small piece of drywall paper or fiberglass screen and press it onto the drywall surface. The patch should cover the hole but should also leave a flat, even surface. Using your joint knife or putty knife, spread another layer of joint compound over the screen and allow the compound to dry.
Step 2 – Apply Compound a Second Time
When the compound covering the patch is dry and you begin sanding, you may discover that the patch surface is slightly indented. If it is, apply another coat of compound and level its surface by drawing the flat edge of your joint knife across it. Be sure the surface is level. When it has dried and after you have sanded you find that the surface is still indented, apply another layer of compound.
Step 3 – Repair Protruding Nail Heads or Screw Heads
When finding a protruding nail or screw head, test it to determine if it is loose or whether it has simply not been driven deeply enough into the drywall and joint. Occasionally, a nail or screw will be driven into the drywall but will miss the stud into which it should have been driven. Pull these nails out of the drywall and fill the hole as described in Step 1. If the nail (or screw) is driven into the wall stud, but is not driven below the drywall surface, use a hammer or screwdriver to hammer it in or drive it further into the wall stud. The head will need to be sunk below the surface of the drywall. Then fill the depression with compound as described in Step 1.
Step 4 – Sand and Paint
When the compound is dry the color in the center will be the same light shade as the color of the compound at the outer edge and you need to use your sand block and sandpaper to sand the surface. Using the sand block will be necessary to insure that the entire surface of the damaged area is flat and is the same level as the surrounding surface. Finally, wipe the dust left from sanding and apply a coat of primer. When the primer is dry, apply a coat of paint that matches the rest of the wall.
 forum activity
