How to Repair Leaks in Basement Walls with Epoxy
what you'll need
- Epoxy Sealant or Injectable Epoxy
- Dispensing Tool
- Wire Brush
- Mortar
- Putty Knife
- Sandpaper
- Paint
- Paintbrush
Basement walls will eventually crack after certain periods of time. When the basement walls crack, water will certainly leak and cause moisture problems inside the basement. To avoid damage caused by moisture, it is necessary to repair the leaks as soon as possible. One of the best ways to repair leaks and cracks is to use epoxy because this material leaves a more durable and stronger seal. Here is how to repair leaks in the basement walls with epoxy.
Step 1 - Examine the LeaksThoroughly inspect the basement walls and check what is causing the leaks first. If broken pipes inside the walls cause the leaks, then professional help may be required in order to repair the pipes found inside the walls. However, if cracks in the walls caused the leaks, then epoxy treatment can be an easy do-it-yourself repair option.
Step 2- Clean the WallsBefore working on sealing the cracks that cause leaks in the basement walls, make sure that the walls are clean enough. Use a wire brush to remove debris and dirt sticking on the walls. Make sure that the walls are dry as well because the epoxy sealant may not stick to wet material. Work on the cracks when it is not raining. Use a blower if necessary to dry the cracks completely.
Step 3 - Fill in Large Gaps with MortarMix mortar with water according to the manufacturer's directions. Fill in the large gaps with enough mortar to cover the crevices. Use a putty knife to drive the mortar deep into the gaps. Allow the mortar to dry.
Step 4 - Apply Epoxy SealantMix a sufficient amount of epoxy material and hardener in a container. Place the mixture in a dispenser tool and apply it on the cracks filled with mortar. Allow the epoxy to dry. Use a sander to smooth the surfaces.
Sometimes, it is best to inject epoxy on the cracks for better results. If the above steps are insufficient, proceed with the next steps.
Step 5 - Use Injectable EpoxyInjecting epoxy into the leaks or cracks is a better way to ensure that the leaks are repaired completely. After cleaning the cracks and allowing them to dry, prepare a mixture of epoxy in a container. Use a dispenser tool to inject the epoxy into the cracks. Allow the epoxy to harden.
Step 6 - Seal the Basement WallsAfter repairing the cracks, sand the surfaces of the walls to prepare it for sealing. Make sure that every crack on the walls is repaired before proceeding. Prepare epoxy sealant according to manufacturer's instructions. Spray the epoxy sealant to every surface of the walls. Do not leave any surface untreated. If necessary, apply a second coating after the first coating has dried. Allow the treatment to dry. Afterwards, paint the room with any color if desired.
