How to Repair or Replace Your Bamboo Curtain Rings
Bamboo curtain rings are designed to attach draperies to a pole. The rings usually have that jointed bamboo style that could beautifully hold and slide the curtain. Most people use bamboo curtain rings for their shower curtains. The use of bamboo curtain rings adds a natural touch to your bathroom. However, bamboo curtain rings will also age and stop looking good since they are a natural material. They can also become damaged. You might consider repairing or changing with a new set of bamboo curtain rings.
Buying New Bamboo Curtain Rings
Most of us will go for replacing it with a new set of bamboo curtain ring instead of repairing. It always feels nice to have something new and refreshing inside the house. When buying new bamboo curtain rings, you need to consider looking at the style. Bamboo curtain rings come in different several designs. One example of a design is a bamboo curtain ring with a metal clip. The mix of bamboo and metal is being emphasized and highlighted on the ring. However, there are also some rings which are entirely made of bamboo or a mix of a plastic material.
Any bamboo design can complement any given décor but it’s always much better if you try to make it even more beautiful by matching the designs. So you need to determine what design of bamboo curtain rings would fit your curtain decoration. You need to look at the current decoration you have in your curtain as well as the design in your curtain rod.
Choosing Your Bamboo Curtain Rings
You need to make sure that the bamboo curtain ring you will buy should match with the current design of your curtain and curtain rod. If you want to change your curtains, still consider matching the designs.
Keeping the Old One
You may choose to repair your old rings rather then find new ones. For bamboo curtain rings which are broken, you can use a strong glue to attach the broken parts. If you are an artistic person, you can consider painting the rings to give it a new design and also to hide the joint of the broken parts. However, if putting back the broken parts together is difficult for you, then you should consider buying a new set.
You should not worry about broken bamboo curtain rings because that only happens if you don’t know how to use the rings or are not careful enough when using them. Bamboo is a strong material which is ideal for holding curtains. When you use bamboo curtain rings, especially those which are designed with a metal clip, you need to ask for the instructions on how to open the clip. In most cases, it is usually the improper releasing of the metal clip that can cause damage to the bamboo curtain ring.
