Login Error
Close
How to Repair Pegboard Plastic Hooks
by DoItYourself Staff
what you'll need
  • Small screwdriver
  • Peg locks or wire ties
  • Adhesive tape
  • Super Glue or epoxy
A pegboard plastic hook is a good substitute to conventional pegboard hangers. It has similar functions like the traditional one but with additional improvements. The improved function of plastic pegboard lies on its capacity to handle more weight as compared to the standard ones. It can also withstand both water and heat with its waterproof and sun resistant capability. It is available in different colors and in "L" and "J" shape. It is made of special plastic material that can easily lock into place and can able to support up to 15 pounds. Pegboard plastic cannot be easily broken on normal circumstances but these are easy to bend. This article will guide you how to avoid and repair pegboard plastic hooks.
Step 1 – Remove the Hooks Properly
It is important that you remove the plastic pegboard hooks properly and carefully to avoid damaging the pegboard and the hook. On thin pegboards, poke the plastic hook to remove it. On thick boards, use a small screwdriver to prod it off. Be careful in using the screwdriver because it may cause the peg holes to enlarge.
Step 2 – Apply Tape or Glue on the Affected Area
Pegboard plastic hooks do not easily break off but in rare case that it will happen, you may use temporary fixes such as adhesive or glue to repair it. Otherwise, it is not recommended to fix it with just tape or glue. You may have to replace it instead with a new one.
Step 3 – Secure the Hooks with Peg Locks
Most often, pegboard hooks easily come off when tools or other items attached to it are removed. Once it comes off, it falls to the floor and may cause damage to it. This can also be an annoying situation that will require you to pick it up again and again every time the hook comes off. To resolve this, choose to use peg locks to secure the pegboard plastic hooks in place. It’s a simple plastic device that tightens the hook to the board. This device can be removed using a flat knife or a screwdriver.
Step 4 - Tips
In normal temperatures, pegboard hooks are strong and durable. But under hot temperature the pegboard plastic hook may become lither thus decreasing its weight capacity. In cold temperatures, the hooks will become delicate causing them to fall apart and break off. In low temperatures it is advisable not to install or remove the hooks to avoid damage on it. Don’t slam the hooks to the pegboard to avoid any damage as well.
Taking care both of the pegboards and pegboard hooks is important because this is where you store items. It is a pegboard system that acts as storage, decorative or tool shed. It’s pretty simple to do that when you follow the tips on this article. Both the pegboard and plastic pegboard hook will continue to work effectively in carrying the stuff attached on it.
 forum activity
