How to Repair Scratches in Wood Glaze Finish
what you'll need
- Rubbing alcohol
- Tweezers
- Putty knife
- Cot tom cloths or old towels
- Sandpaper
- Wood finish
- Wax putty (same color as the wood glaze you are repairing)
Nothing is worse than seeing a deep scratch or a gouge deep in your wood glaze, especially if you just recently have gotten a floor put in. With a few simple steps, you can repair these scratches and your wood glaze will look good in no time.
Step 1 - Cleaning the Surface
With a wet towel, completely clean the surface that has the scratch or gouge. Take a cotton ball and dip it into the rubbing alcohol. Next, take the cotton ball and clean the scratched area. This will ensure that there is no dirt in the crack, the placing of putty can look awful if there is still debris on the floor. Re-wipe the area with the cotton ball if you still see dirt.
Step 2 - Applying Putty
With a putty knife, take some putty to put into the scratch. You want to make sure that the putty gets all the way into the scratch. You may need a smaller knife to do this, or for really small scratches, you can use a pair of tweezers. You may need to move the knife or tweezers up and down to ensure that the putty gets completely in. Don't be afraid to use a little force.
Step 3 - Smooth Out the Putty
With the back of the knife, you want to smooth out the putty above the scratch. You can do this with a gentle back and forth motion.
Step 4 - Remove All Excess Putty
Now with the back of the knife scrap off any excess putty. Gently graze the area with the blade of the knife.
Step 5 - Rubbing the Scratch with a Cloth
Now you can take a cloth or towel. With the towel you want to rub down the area you just applied the putty to. Don't be afraid to use full force when doing so.
Step 6 - Sanding Down the Scratch
With a piece of sandpaper, you want to sand down the scratch. Make sure the grain side is up. You can rub using a circular motion. Make sure to rub the area surrounding the scratch as well. This will ensure an even finish.
Step 7 - Wiping Down the Area
After you finish sanding, wipe down the area with a damp cloth or towel. Allow time for the floor to dry.
Step 8 - Applying Hardwood Floor Finish
With a paintbrush, apply floor finish to the area. Dab the brush in the hardwood floor finish and rub it on top of the scratch. Be careful not to add too much finish to the floor. Remember less is more. Too much finish can alter the color of the floor. Apply about four to five layers of finish. Let the floor dry. As the floor is drying, be sure that no dirt falls upon it.
