Login Error
Close
How to Repair Travertine Wall Tile
by DoItYourself Staff
Travertine wall tiles add a touch of elegance to your bathroom or kitchen wall or where ever they are installed. They give a very warm feeling and can be installed on various surfaces. Usage over the years might damage the travertine wall tiles and then you must repair it or replace it. Repairing the travertine wall tile is very easy and requires just few basic tools.
Requirements
  • Safety Glasses
  • Tile Grout
  • Grout Sealer
  • Adhesives
  • Work Gloves
  • Large Sponge
  • Notched Trowel
  • Chisels
  • Hammers
  • Carbide hole saw
  • Nails or Screws
Step 1: Purchase the Replacement Tile
Go to any home development store and purchase travertine tiles that match the one that you are going to replace. Take a proper measurement of the damaged tiles and then purchase accordingly. Make sure the thickness of the new tile matches with the old damaged one. For this reason it is better to purchase the replacement tiles after removing the old damaged ones. Also purchase some adhesive and grout mix from the store.
Step 2: Removing the Damaged Tiles
Use the carbide hole saw to drill a hole in the centre of the damaged tile to make an estimate of the depth of the tiles. Once this is done drill holes on the surface of the damaged travertine tile at an interval of 1 inch. Be very careful while drilling the hole and make sure you are not damaging the sub floor. If the subfloor is damaged, it is a difficult repair and so you must be careful from the beginning. Once the holes are drilled properly use the chisel to remove sections of the damaged travertine tiles. Use the hammer for getting more leverage and you can also use a putty knife for removing the tiles from the floor. You can use a chipping hammer for removing the travertine tiles very fast and efficiently as they crumble easily.
Step 3: Preparing the Surface
Once the damaged tile is removed, use the chisel or an awl to remove the grout from the adjacent tiles. Use a knife to scrape the old adhesive or mortar from the floor where the damaged tile was present. You must make sure that the floor is smooth and there are no uneven parts present on the floor. Doing so ensures that the new tile will fit in perfectly and it will also last long. If the flooring is damaged while removing the old tile, repair it before installing the new travertine tile.
Step 4: Installing the New Tile
Once the floor is prepared and you have purchased the new travertine tiles it is now time to install them. Measure the portion from which you have removed the old travertine tile and if necessary cut the new tile with a wet tilt saw to get a perfect fit. Apply a thin layer of mortar or adhesive on the wall and press the new tile in position. Allow the adhesive or mortar to dry and then apply grout for sealing the joints.
 forum activity
