Login Error
Close
How to Repair Wallpaper that Is Peeling Off
by DoItYourself Staff
what you'll need
  • Sponge
  • Paintbrush
  • Painter's tape
  • Wallpaper repair glue
  • Wallpaper seam roller
If any area of your home has fallen victim to peeling wallpaper, you may be wondering how to repair your wallpaper. Fortunately, repairing loose wallpaper is much easier than you may think.
Step 1 - Apply Your Wallpaper Repair Glue
Begin the wallpaper repair process by using your hands to pull back on the loose piece of wallpaper. Continue to pull until you reach the point at which the peeling ends and the wallpaper is securely attached to the wall. Next, you will need to use a small paintbrush to apply a thin layer of repair glue to the loose piece's back end. Applying too much glue is liable to result in the formation of air bubbles, so when performing this step, thinness is key. Once your glue has been properly applied, firmly press the loose piece of paper back into place.
Step 2 - Tighten the Seal
Having reattached the loose paper, you will now need to gently smooth it out with the aid of a damp sponge. After getting rid of any air bubbles, run a wallpaper seam roller over the newly reattached piece of paper in an up-down motion. Next, place pieces of painter's tape along the sides of the reattached paper, then allow it to sit for 24 hours. Once your glue has been given ample time to dry, remove the tape. Should the peeling reoccur, repeat steps 1 and 2.
The next time you need to repair loose wallpaper, just remember these two easy steps and you'll be able to complete the job in a timely and stress-free fashion.
 forum activity
