How to Replace a Corner Shower Rod
what you'll need
- Screwdriver
- Mounting Hardware
- Corner Shower Rod
- Measuring Tape
- Pencil
- Pry Bar
- Hammer
- Hack Saw
- Drill
Since the shower is a moist area, the corner shower rod can get rusted, moldy, or simply out of date. Although not a very important part of the shower décor, the corner shower rod provides a lot of functions that are deemed necessary for the shower. When installed, it can hold the shower curtains that add beauty to the room. The shower curtains also act as a water barrier that prevents the other parts of the bathroom from getting wet. Replacing a corner shower rod is not a very hard task to do. With the most basic skills and tools, anyone can do the task in no time.
Step 1 – Removing the Old Rod
Removing the old rod is very simple. First, remove the shower curtain from the rod and determine what type of mounting hardware is used to fasten it to the wall. If the rod is simply screwed to the wall studs, use a screwdriver to loosen the screws. If the rod is mounted using anchors, then the removal process may require harder work.
For the most common types of anchors, follow these steps: position the pry bar at the anchor head and pound the pry bar with a hammer until the anchor comes loose, and if necessary, cut the anchor using a hack saw. For other types of anchors, research on how they are best removed. When the mounting hardware is removed, pull out the old rod to make way for the new one.
Step 2 – Choosing a Replacement Rod
Determine which type of replacement rod is best for the corner shower. This will depend on the design of the corner shower. The L-shaped rod is the most common, but there are also other rods that are curved in shape. Determine what type of mounting hardware the rod needs as well. If the shower wall is made of cement, then anchor bolts may be required for the installation. If the shower has studs in which to mount the device, then screws will work well enough.
Step 3 – Prepping the Walls
Determine how high the replacement rods will be installed. This will depend on many factors, such as the length of the curtain to be used, the height of the wall, and the average height of the persons using the shower. When the best height is decided, position the rod on the wall to check where the mounting hardware will be installed. Mark the spots for later drilling. Take note that some shower rods come with an added support that has to be installed to the ceiling. Mark the mounting spot on the ceiling as well.
Step 4 – Mounting the Rod
Drill the marked holes in the wall and make sure to follow the recommended diameter and depth. While holding the rod, install the screws or mounting hardware starting from one side of the wall. Check if the rod is secured into place before installing the curtains.
