Login Error
Close
How to Replace a Dryer Seal
by DoItYourself Staff
what you'll need
  • Dryer seal
  • Wrench
  • Working gloves
  • Measuring tape
To replace dryer seals is an operation that can be done at home by following the correct procedures and using appropriate tools. This device can interfere with the performance of the dryer vent if it is spoiled, damaged, corroded or it has rust. Watch out against such problems by inspecting the vent regularly and following maintenance practices such as cleaning out dirt and debris
Step 1 – Buy Dryer Seal
Get the correct type of dryer seal to fix in the vent by measuring the diameter of the old device. Use a tape measure to get the correct dimensions; this can be used to buy the right size to be installed in the dryer vent. Buy quality device that is guaranteed to last for a long duration when providing quality service. Some of the best devices to buy are made from ABS plastic material.
Step 2 – Open Dryer Vent
Switch of the device and unplug it from power outlet. Do not attempt to carry out repairs at home on devices that are connected to power supply. This can lead to injuries such as electrical shock or electrocution.
Use wrenches to loosen the dryer seal from the vent. Apply pressure as it might be held on the device too tightly. Use hands to dismount the device from its point of connection.
Step 3 – Inspect Dryer Vent
Check for dirt, residues, rust or corrosion on the dryer vent. If necessary clean the vent to maintain and keep it in good condition. Use a brush to remove dirt and particles. Look out for wear and tear, rust or corrosion on the device and consider making a replacement.
Step 3 – Replace Dryer Seal
There are vents that use 2 seals. Get 2 devices for such dryer vents. Place the vent in position using hands and fasten them in place using wrenches. Make sure the connection is secure and tight as they can easily get blown off or loose due to pressure released in the vent.
Step 4 – Reassemble the Vent
Make sure that the pipe is in good condition and all components are securely fixed in place. Plug the equipment back to a power outlet and turn on the switch. Check whether the new dryer seal is working correctly.
Maintenance
There are components in the dryer vent system that tends to wear and tear quickly due to their operation. This includes the pulley, belt and rollers. Inspect these components regularly. They make it possible for the appliance to perform at top condition. Buy them when getting a dryer seal from hardware or home supplies stores and fix them when making repairs.
Tips
  • Adhesive can be used to secure the connection between the new seal and dryer vent.
  • Install a dryer seal to keep dyer vent safe from pests, insects, leaves, debris, unwanted moisture and air.
  • Keep the dryer vent clean by removing lint and debris. If left to accumulate in the appliance, they can cause it to spark and catch fire.
 forum activity
