Login Error
Close
How to Replace a Dryer Vent Hose
by DoItYourself Staff
what you'll need
  • Vacuum cleaner
  • Metal duct collar
  • Exterior dryer vent
  • Metal shears
  • Drilling machine
  • Metal screws
  • Caulk
  • Duct tape
  • Dryer vents hose
  • Metal clamps
When a dryer vent and its hoses get clogged with lint, they can pose a serious fire hazard. In addition to preventing fire, cleaning the dryer vent or replacing the hoses helps in increasing the dryer’s efficiency. Most importantly, this is not difficult to do and you can do it yourself without having to spend much money, especially in hiring any professional. In nutshell, the benefit obtained by replacing the clogged vent in terms of safety and efficiency is more than the cost that you would incur in doing so. Hence you are advised not to delay the replacement if the need arises. Here's how you do the job.
Step 1 – Inspect the Current System
Inspect the current ventilating system of your dryer. This consists, mainly of a hose that runs from the dryer’s back to a vent attached to building's exterior. You will need to replace the old, cracked or damaged materials.
Step 2 – Purchase the Material
You can choose to purchase either the individual materials or an all-inclusive kit.
Step 3 – Individual Materials
The individual materials include an exterior vent which prevents the critters from entering, a rigid metal, a duct collar and an aluminum hose.
Step 4 – Locate Metal Clamps
Locate the metal clamps or the duct tape to attach the hose to dryer, and the metal duct collar that leads to exterior vent.
Step 5 – Vacuum the Dryer Vent
Remove the existing exterior vent and vacuum the opening to remove any clogged lint and to clean the dryer vent.
Step 6 – Mark Holes on Wall
Check the fitting of the new vent into the exterior opening. To fix the vent to wall, mark locations for the holes on wall.
Step 7 – Cut the Collar
The length of the new collar should be same as the old collar. If the new one is longer, cut it using the metal shears.
Step 8 – Place the Collar and Vent
Now, insert the collar into vent and fix the vent into the exterior opening.
Step 9 – Fix the Vent to Wall
Use a drilling machine to make holes in the wall as per the markings made earlier. Using the screws, fix the vent to wall.
Step 10 – Apply Caulk
To seal it properly and prevent any leaks, apply caulk around the wall and vent seam.
Step 11 – Replace the Hose
Now, replace the existing hose with a new one. The total number of bends and twists in the hose from dryer to vent should be as low as possible.
Step 12 – Secure the Hose
Use either the metal clamps or the duct tape to fix the hose at either end.
That's it; you have successfully replaced the dryer vent hose, and have saved some money by doing the job yourself.
 forum activity
