Login Error
Close
How to Replace a Garbage Disposal Air Switch
by DoItYourself Staff
There are two types of garbage disposal air switch and these switches are very safe to use. The garbage disposal air switch uses air to control the unit and is thus very safe as there is no chance of any electrical shock. The air switch uses a plunger type button and it can be installed on the sink or the counter top and the garbage disposal switch can be very easily installed and replaced. When this plunger is depressed it pushes air through tubing that goes to the base of the sink and then it turns on the garbage disposer. For various reason this switch can get damaged, requiring replacement. The garbage disposal air switches are easily available in the market and the come in various finishes. So for replacing the switch you do not need to search for it very much.
Requirements
  • Garbage disposal air switch
  • Rubber gasket
  • Drill
  • Screwdriver
  • Cutter
  • Plastic nut
Step 1: Uninstall the Damaged Air Switch
Uninstall the damaged switch by using the screwdriver and pull it out from the base of the sink. Uninstalling it is very easy as you have to just unscrew it and pull it out. Now it is installed generally on the sink or the counter top and also many times on the wall nearby. If when replacing the air switch you also want to change its position on the wall, use the drill to make a ¼-inch hole to install the new switch.
Step 2: Mounting the New Switch
Once you have opened the old switch buy a new one matching the configuration of the old one and then mount the new switch in your chosen position. For the air switch on the outside use a rubber gasket on the top of the counter top. Tighten plastic nuts from below the sink to fix the gasket and the part of the switch that goes on the top. The new switch can be installed in the same manner in which the old one was present.
Step 3: Attach the Tube to the Bottom of the Sink
Once the top portion of the switch is in place you need to install the rubber tubing that will go down in to the bottom of the sink. You can use the old rubber tube else if it is damaged buy a new one or it comes in the air switch kit. Attach bone end of the rubber tube to the switch and the other end goes in to the converter at the base of the sink. It is unnecessary to have a long tube attached over there so use the cutter to have a tube of the desired length.
Step 4: Check the Installation
Once the replacement is complete, check the system and see that there is no leak present. If still there are leaks present, use plumbing putty to seal them. Make sure the base of the sink is dry while you are making the installation.
 forum activity
