Login Error
Close
How to Replace a Garbage Disposal Splash Guard
by DoItYourself Staff
what you'll need
  • Flat-head Screwdriver
A garbage disposal splash guard can be a challenging process to replace. This, like any other do it yourself home repair project, can be difficult if you don't have the right information.
Step 1: Turn off the Breaker Switch that Controls You Garbage Disposal
You should never take chances with your safety. The first rule of every job that involves electricity it to make sure that you can't get hurt. This is the first step that you should always take.
Step 2: Remove the Drain Pipe form the Disposal
You should start the project by removing the drain pipe from the side of the garbage disposal. This requires that use of a flat blade screwdriver. You should loosen the screws by turning them in a counter clockwise direction until they come out of the garbage disposal.
Step 3: Separate the Garbage Disposal From the Sink
Wedge the screwdriver between the dog ears where the sink meets the garbage disposal. Push it in a clockwise direction about 1/4 of a turn. The garbage disposal will unlock and fall off of its sink mount.
Step 4: Remove the old Garbage Disposal Splash Guard
Now is the big moment. You are going to reach into the garbage disposal and remove the garbage disposal splash guard. You have now removed your garbage disposal splash guard.
Step 5: Make sure that the Garbage Disposal is Clean on the Inside
Make sure that you have checked your garbage disposal to make sure that nothing has fallen down inside the disposal unit. Over the years of use a lot of things get dropped down your garbage disposal and now is the best time to remove them.
Step 6: Put the new Garbage Disposal Splash Guard back in the Disposal
Well here you are at the moment that you have been waiting for. It's time to put the brand new garbage disposal splash guard back in the garbage disposal. Just put it back in the same place that you just removed the old one from and you will have replaced your garbage disposal splash guard.
Step 7: Put the Garbage Disposal Back in Place
Now all you have to do is put the garbage disposal back in place on its mount, in the unlocked position, and use the screwdriver to put it back in place. Give a good push on the handle of the screwdriver, making sure that the garbage disposal is in place where it's supposed to be.
Step 8: Replace the Drain Pipe
Make sure that you have put the drain pipe back in place where it belongs. Your garbage disposal splash guard should last awhile now. It should keep the food and water out of your face.
Ste 9: Turn the Breaker Switch on again
Turn the electric breaker switch that you turned off back on again and you’re ready to test your new garbage disposal splash guard.
 forum activity
