Login Error
Close
How To Replace a Mobile Home Window
by DoItYourself Staff
what you'll need
  • Putty
  • Screws
  • Screwdriver
  • Drill
  • Sealant
  • Any other mobile home supplies recommended by the manufacturer
A mobile home will require some level of maintenance and repair in order to ensure that it will provide many years of use. There will probably come a day when a window in your mobile home will need to be replaced. This can be a very manageable task and one which you can achieve yourself if finances don't permit you to hire a professional.
Step 1: Measurements and Fittings
Start by measuring your window. You will need to ensure that your new window is exactly the same size. If it's slightly too big, it simply won’t fit. If the window is too small, you risk letting in wind and rain.
Check how your window is mounted. If it is flush mounted, it will screw on over the siding. If it's a lap-siding mount, the screws will cover the window frame screw holes. It's important to check the type of mount because this will make installation easier and also ensure that all your windows look the same. You might need to contact a mobile home manufacturer, because they will be able to advise where to purchase the correct window for your home.
Step 2: Remove Window
Using a drill, carefully remove all the screws that hold the current window in place. Once the screws have been taken out, carefully remove the window and its frame. Do not re-use these old screws, as they will be worn. Instead, use new screws that are the same diameter and length as the old screws.
Step 3: Clear Putty or Sealant
Remove all the old putty from the window frame. Try to ensure that it is all gone and use a wire brush if necessary to completely clean the area. Once all the old putty is gone, start to apply new putty to the window frame. You should apply two layers of putty at the top of the opening, as this will provide an extra layer of protection against moisture.
Step 4: Getting Started
To insert your new window, you will need to insert one new screw into the middle hole on each side of the window frame. Try to ensure that the screws go in straight, but do not tighten them until all the screws for the window are in place.
Step 5: Check for Square and Finish
Before inserting more screws into the frame, check to make sure that the window is square and that it can be opened and closed without any bending. Once you are satisfied with your window, insert the corner screws and any other remaining screws and tighten them all.
Step 6: Final Touches
Run a line a sealant along the window where it meets the sliding. Test the window once more to ensure that it opens without bending and that it is still square.
 forum activity
