cancel
Job type :
Zip Code :
community forums
comments
How to Replace a Sliding Glass Door Panel
Replacing the sliding glass door panel in your sliders is not a difficult project and you should be able to accomplish it in a short period of time.
Removing the Doors
On the top of most sliding glass doors there are adjustment screws that allow you to adjust the door up or down. Loosen the screws to allow you to take the door down and remove it. There are some models of sliding doors that put the adjustment screws on the bottom of the door as well.
If you are only removing the doors and not the entire frame, you can simply reinstall the new door now. Otherwise, there are screws that hold the frame in place. To remove the frame, find the screws and remove them from the wall of your home. This will allow you to remove the frame and replace it with a new one.
Repairing Your Sliders
Repairing the various components on your sliders is relatively simple. You can usually find additional parts from the manufacturer of your sliders to replace broken or defective parts. Replacing the glass may require you to remove the entire glass door and replace it with a new one. These should also be available from the manufacturer.
member comments
Related Articles
Closet Door Repair versus Replacement - What to Choose
Closet door repairs generally aren't difficult... read more
How to Install a Garage Door Opener
Step-by-step instructions for installing an automatic garage door opener... read more
Sliding Glass Pet Door Logistics
A sliding glass pet door is a pet door associated with a sliding glass patio... read more
articles we like
Too Much Room? Make It Look Full Without Spending Too MuchToo Much Room? Make It Look Full Without Spending Too Much
How to decorate a large room without spending too much money... read more
Site Work
Site work is a term used to describe any work done when preparing a site... read more
Learn Trump's real estate secrets at free seminarLearn Trump's real estate secrets at free seminar
There is prime real estate available at incredible prices, just waiting for the right person... read more
sponsored articles of the day
diy centers
