Login Error
Close
How to Replace a Sliding Window Lock
by DoItYourself Staff
what you'll need
  • Hammer
  • Newslidinglock
  • New window frame
  • Small brush
  • Cleaning cloth
The sliding window lock is one important item in the house if there are any small children and pets. This item proves to be very helpful in locking windows partially open, so that fresh air can still be enjoyed, without having to worry about any children or pets evading from the house. This article will speak about how to replace a slidingwindow lock.
Step 1 – Inspection
Firstly, inspection is required. Inspect the area and confirm that there is nothing blocking the track, where the lock slides along. This will not allow locking the window. Make sure that the cleaning of the window track is also done with the help of a small brush or a cloth to sweep it.
Step 2 – Repairing the Window Track
The next step is to check if the problem is with the window track or with the window lock. Make sure to inspect the window track, is the lock is not sliding. For example, if the window frame is not straight, then with the help of a hammer, bang the frame, in order to get it into shape. If this doesn’t work, then make sure to replace the entire window frame.
Step 3 – Replacing the Lock
Lastly, the window lock might be broken. So, with the help of a screwdriver, start unscrewing the lock, replacing it with a brand new one.
In this way, the sliding window lock can be replaced. The tools and the materials required can be purchased from any home improvement store.
 forum activity
