How to Replace a Toilet Seal
what you'll need
- Replacement toilet seal (wax ring)
- Adjustable wrench
- Rubber gloves
- Putty knife or scraper
- Mineral spirits or rubbing alcohol
If your toilet rocks back and forth or if there is a leak under the base of the toilet, there is a good chance that you will need to replace the toilet seal or wax ring. Over time, a wax ring can become deformed or damaged and will need to be replaced. Replacing a faulty toilet seal is an easy DIY project, and this simple how-to guide will show you everything you need to know. Let's get started.
Step 1 - Shut Off Water to Toilet
Shut off the water to the toilet by turning the inlet water valve at the base of the wall directly underneath the toilet tank. When shutting off the water, you should turn the valve clockwise until it is completely closed.
Step 2 - Drain Toilet
in order to drain the water in the toilet, you simply need to use the flush handle to flush the toilet. Once the toilet is flushed, the tank should not refill if the water has been shut off.
Step 3 - Remove Toilet Anchor Bolts
On most toilets, there are two anchor bolts installed on both sides of the toilet. These bolts are usually covered with plastic dome caps that can be removed with a flat head screwdriver. Remove the caps, and then use an adjustable wrench to loosen and remove the anchor bolts that hold the toilet into place.
Step 4 - Remove Toilet
Remove the toilet by lifting it off of the anchor bolts, and then turn the toilet upside down so that you can reach the base of the toilet. Use a putty knife or scraper to scrape away any old wax or dirt and grime that may have built up on the base of the toilet.
Step 5 - Remove Old Wax Ring
While wearing rubber gloves, remove the old wax ring from the drain flange. The wax will probably be greasy, grimy, and fairly disgusting, so make sure you use gloves. Discard the old wax ring.
Step 6 - Clean Flange Area
Use a putty knife or scraper to scrape away any excess wax. Then, use an old rag and some warm water to wash away any wax residue or buildup that may be left over.
Step 7 - Install New Toilet Seal
Lay the new toilet seal into place over the drain flange. Refer to the diagram on the packaging on how to properly place the wax ring.
Step 8 - Replace Toilet
Set the toilet back into place slowly and over the two anchor bolt positions. Then, apply even pressure on the toilet so that it seals with the new wax ring. Don't tilt or rock the toilet while you are setting it on the new toilet seal, as this will cause the new wax ring not to seal properly. Reattach the nuts to the anchor bolts and replace the plastic cover caps.
Step 9 - Turn On Water
Open the inlet water valve by turning the handle counterclockwise. The toilet should now be working properly, and there should no longer be any leaks from the wax ring.
