Login Error
Close
How to Replace a Vehicle's O2 Sensor
by DoItYourself Staff
what you'll need
  • Service manual
  • Deep well socket
  • New O2 sensor
The O2 sensor performs a vital function in a vehicle. It acts as a monitor for how much oxygen is needed through the air intake, which is then fed into the chamber for combustion. When you’re having problems with the engine running sluggishly, or a “Check Engine” light on the dash, you might need to replace the oxygen sensor, which is something you can do yourself.
Step 1 - Preparation
Start by giving the vehicle a tune up. If you’re still having problems after this, then you will probably need a new O2 sensor. Buy this from the auto parts store, being certain to purchase the correct one for your vehicle; they’re not all the same. Have your vehicle parked on the driveway and give the engine ample time to cool before beginning the work. You also need to disconnected the negative battery cable to avoid any possible electric shocks as you work.
Step 2 - Location
You need to discover the location of the O2 sensor in your vehicle. The simple way is to check in your service manual. There are two possible places for the O2 sensor. It might be close to the catalytic converter, but on the engine side. This is known as upstream, or pre-cat. It can also be closer to the tail pipe, which is called downstream or post-cat. The sensor itself will be screwed into place so you don’t need to take the entire system apart in order to reach it.
Step 3 - Connections
The O2 sensor is connected by wires to the vehicle’s electrical system, and you need to disconnect it prior to removing it. Generally this will involve a clip. If rusty, use WD40, allow it to penetrate and the remove the clips.
In some models the O2 sensor has everything in a snap-on connector. This eliminates the news to unscrew the sensor and remove the electrical connectors. Be aware of how your sensor connects.
Step 4 - Removing
In most instances, you’ll need to use a deep well socket to remove the O2 sensor from the exhaust. It should come out easily, especially if you’ve used WD40 first to penetrate the connections.
Step 5 - New Sensor
Where the wires are connected via a snap-on connector, cut the wires leading to the old connector and re-wire them to the new sensor by stripping and twisting the wire ands and using electrical tape. Be sure to match the colors correctly or the sensor simply won’t work.
Where needed, use the socket to tighten the sensor into place, being careful not to tighten too much, and then attach the snap-on connector. All the work under the car is complete. Put the negative cable back on the terminal, and turn the engine to “On.” This should eliminate the problem and the “Check Engine” light should no longer be on (although you might need to feed in a code through a computer to remove it).
 forum activity
