How to Replace an Engineered Floor
what you'll need
- Pry Bar
- Screw or Nail Gun
- Screwdriver
- Hammer
- Chisel
- Sealer Preservative
- Tape Measure
- Circular Saw
- Nails
- Engineered Flooring
- Plywood Sheets
An engineered floor can be replaced in the same manner as any type of wood flooring. Engineered wood flooring is flooring that consists of 3 to 7 plies or layers of varying thickness. The number of plies adds to the strength of the wood and makes it cheaper than solid wood flooring of the same core type or species, such as oak.
When your existing engineered flooring is in need of replacement or repair, below are the tools, materials and steps needed to replace the flooring.
Step 1: Purchase Materials for the Floor Replacement
You will need to go to a lumber yard or home improvement center to purchase the engineered wood flooring needed for the replacement. Measure the existing flooring ahead of time and calculate the total square footage of the room where the flooring will be laid. The square footage is calculated by measuring the room's length and multiplying it by the width. With this information the sales associate assistant can use a floor calculator to determine the amount of wood needed in order to complete the job.
Step 2: Remove Existing Flooring
Use a pry bar to remove the nails and screws that hold the engineered floor boards in place. You will need to pry up all of the existing flooring and toss it in a waste container before you move to the next step in the replacement process of the room's engineered flooring.
Step 3: Inspect the Floor Joists and Subflooring
While the flooring is up you should inspect the floor joists in order to determine if they are properly installed or in need of replacement or adjustment. The floor joists, which should be under the plywood subflooring, are the cross beams through which the flooring will be attached. In addition to the joists, replace rotted or damaged subflooring with 1/4 inch or 1/2 inch plywood sheets.
Step 4: Replace Floor Boards
With the floor boards completely removed and the joists and subflooring inspected or replaced, replace the floor boards with the new engineered floor boards. Use a screw gun or a nailer to attach the floor boards to the joists. They can also be glued to the subflooring or allowed to float in the case of a floating floor that uses a tongue and groove installation method.
Step 5: Clean the Work Area
Properly dispose of all of the flooring that was removed and place it in the appropriate recycling location within your community. Clean up any dust and residue on the engineered flooring that you installed and apply a coat of wax or sealant as recommended by the manufacturer. Be sure that the floor is completely dry and clean before you place any removed furniture back into the room. With this step completed, you are now ready to enjoy your engineered flooring.
