How to Replace Corrugated Plastic Roofing
what you'll need
- Corrugated plastic sheets
- Hammer
- Nail Gun
- Marker
- Band saw
- Measuring tape
- Ladder
- Nails
- Prybar
- Screws
- Vise grip pliers
- Powered screwdriver
If your corrugated plastic roofing has cracked, sprung a leak, or needs to be replaced for any other reason, you may want to simply do the project yourself to avoid the time and money it would cost to hire a professional. With a little patience and attention to detail, this is a job that you should be able to complete yourself. Follow the steps below to learn how to complete this project.
Step 1 - Obtain Help
This will be a very difficult, if not impossible, job to complete by yourself, so you will most likely have to employ the assistance of 1, and preferably 2, friends to help you complete this project. Ideally, you will have 2 people on top of your roof to receive the plastic sheets as 1 person below passes them up.
Step 2 - Remove Old Roof
Since you are replacing a previously extant corrugated plastic roof, the next thing you will need to do is remove the previous roof. This will typically be held together with a combination of screws and nails, so you will use a combination of a screwdriver, claw hammer and a prybar (if necessary) to remove the old roofing material from its framing boards. Once you have removed the old roof, you will be ready to install the new roof.
Step 3 - Cutting Corrugated Plastic
Corrugated plastic typically comes in sheets, and you will most likely have to cut the sheets to the proper length before installing them. To do this, you can either use the old roofing sheets as a guide for your dimensions or you can use a measuring tape to determine the dimensions you will need for your sheets. Measure the correct dimensions on the sheet of corrugated plastic and use a marker to draw a line marking your cuts. Then, use a band saw to cut through the corrugated plastic to give yourself the proper length of sheet.
Step 4 - Inspect Wood for Damage
Before going ahead and installing the plastic corrugated roofing, it will be in your best interest to make sure that the wood you will be attaching the roof to is not damaged by rotting or any other negative condition. While you have the roofing off, it will be your best opportunity to fix any damaged wood, as opposed to after you have installed the roofing permanently.
Step 5 - Install Corrugated Plastic Roofing
It will be up to you whether you want to use nails, screws, or a combination of the two to attach your plastic corrugated roofing to the roofing boards. Screws will typically be your best bet for stability, but a combination of the two will usually be best. Begin by using a nail gun to drive nails through the corrugated plastic into the ridges of the roof. When you reach the end of one sheet of plastic, simply overlap the pieces to achieve a seal. Once you have nailed the sheets in place, follow this by attaching screws with watertight washers into the flat areas between the roof ridges.
